Is there an example for custom load extension demonstrating APDL commands encapsulation on a multist
Pernelle Marone-Hitz
Member, Moderator, Employee Posts: 900
Is there an example for custom load extension demonstrating APDL commands encapsulation on a multistep problem.?
Here is an example.
.xml file:
<extension version="1" name="multiStep"> <guid shortid="multiStep">66F87991-B66E-425E-B2E6-D2C5C1DF31D9</guid> <script src="main.py" /> <interface context="Mechanical"> <images>images</images> <toolbar name="multiStep" caption="multiStep"> <entry name="multiStep_Check" icon="Thermal"> <callbacks> <onclick>createLoad</onclick> </callbacks> </entry> </toolbar> </interface> <simdata context="Mechanical"> <load name="multiStep" version="1" caption="multiStep_Check" icon="Thermal" issupport="false" isload="true" color="#0000FF"> <callbacks> <getcommands location="solve">writeLoad</getcommands> </callbacks> <property name="Geometry" caption= "Geometry" control="scoping"> <attributes selection_filter="face" /> </property> </load> </simdata> </extension>
main.py file:
def createLoad(currentAnalysis): load = currentAnalysis.CreateLoadObject("multiStep", "multiStep") def writeLoad(load, solverData, stream): # Direct # if solverData.CurrentStep == 1: # stream.Write("D, All, UZ,5" + "\n") # elif solverData.CurrentStep == 2: # stream.Write("D, All, UZ,10" + "\n") ###########Using readlines####### #Scope only named selections## SourceDir = ExtAPI.ExtensionManager.CurrentExtension.InstallDir macFile1 = "step1.inp" macFile2 = "step2.inp" ns = load.Properties["Geometry"].Value.SolverName ExtAPI.Log.WriteMessage('2nd Method') if solverData.CurrentStep == 1: stream.Write("cmsel,s," + ns + "\n") fs1 = open(os.path.join(SourceDir, macFile1), "r") allLines1 = fs1.readlines() fs1.close() stream.Write("".join(allLines1)) elif solverData.CurrentStep == 2: stream.Write("cmsel,s," + ns + "\n") fs2 = open(os.path.join(SourceDir, macFile2), "r") allLines2 = fs2.readlines() fs2.close() stream.Write("".join(allLines2))
step1.inp:
/solu D, All, UZ,5 allsel,all
step2.inp:
/solu DDELE,ALL,ALL D, All, UZ,10 allsel,all
