Example of exporting and importing legend settings
Pernelle Marone-Hitz
Member, Moderator, Employee Posts: 894
Below is an example. Note - it uses undocumented / unsupported commands.
import os import units def write_legend_settings(result,filepath,guid): min_qty = result.MinimumOfMinimumOverTime max_qty = result.MaximumOfMaximumOverTime minimum = units.ConvertUnit(min_qty.Value, min_qty.Unit, "Pa") maximum = units.ConvertUnit(max_qty.Value, max_qty.Unit, "Pa") template = '''<?xml version="1.0" encoding="UTF-8" standalone="no" ?><styles version="11"><style colorMode="0" contourCount="9" editable="-1" factoryStyle="0" guid="{}" independentBands="0" log="0" mode="1" name="0_9999" namedStyle="-1" numericMode="1" orientation="1" significantDigits="5" transparency="0" unitless="0"><band color="0" colorAuto="-1" label="" value="{}" valueAuto="0"/><band color="0" colorAuto="-1" label="" value="0" valueAuto="-1"/><band color="0" colorAuto="-1" label="" value="0" valueAuto="-1"/><band color="0" colorAuto="-1" label="" value="0" valueAuto="-1"/><band color="0" colorAuto="-1" label="" value="0" valueAuto="-1"/><band color="0" colorAuto="-1" label="" value="0" valueAuto="-1"/><band color="0" colorAuto="-1" label="" value="0" valueAuto="-1"/><band color="0" colorAuto="-1" label="" value="0" valueAuto="-1"/><band color="0" colorAuto="-1" label="" value="0" valueAuto="-1"/><band value="{}" valueAuto="0"/></style></styles>'''.format(guid,minimum,maximum) with open(filepath,'w') as f: f.write(template) def import_settings(filepath): cmds = ''' var filePath = "{}"; var refLegendStyleMgr = WB.ScriptEngine.Engine.CreateActiveXObject(WB.ScriptEngine.Engine.GenWBProgId("AnsCoreObjects.AnsLegendStyleManager")); var callback = WB.ScriptEngine.Engine.CreateActiveXObject(WB.ScriptEngine.Engine.GenWBProgId("AnsCoreObjects.AnsDelegate")); callback.AddCOM(this, "OnOverwriteStyle"); refLegendStyleMgr.ImportStyles(filePath, callback,true); '''.format(filepath.replace('\\','\\\\')) ExtAPI.Application.ScriptByName("jscript").ExecuteCommand(cmds) maxstress=ExtAPI.DataModel.Project.Model.Analyses[0].Solution.Children[1] folder = r'D:\Temp' legend_xml = os.path.join(folder,'legend_settings.xml') guid="{79E20481-9999-46CF-8389-A1B633E3E555}" write_legend_settings(maxstress,legend_xml,guid) import_settings(legend_xml) legend = ExtAPI.DataModel.InternalObject["ds"].Graphics.GfxUtility.Legend legend.ApplyLegendStyle(guid)
