Exporting kinetic energy of each element in each cartesian directions for all modes in modal
Pernelle Marone-Hitz
Script for exporting kinetic energy of each element in each cartesian directions for all modes from modal analysis
    edited December 2023
    Adapt the following code:
    def EvaluateDirectionalKE(mode):
        import math
        import units
        reader = Model.Analyses[1].GetResultsData()
        reader.CurrentResultSet = mode
        mesh = Model.Analyses[0].MeshData
        freqs = reader.ListTimeFreq
        elementIds = mesh.ElementIds
        deformationx = reader.GetResult("U")
        deformationx.SelectComponents(["X"])
        deformationy = reader.GetResult("U")
        deformationy.SelectComponents(["Y"])
        deformationz = reader.GetResult("U")
        deformationz.SelectComponents(["Z"])
        deformation_total = {}
        deformation_ratio_x = {}
        deformation_ratio_y = {}
        deformation_ratio_z = {}
        KE_X = {}
        KE_Y = {}
        KE_Z = {}
        KE = {}
        energy_result = reader.GetResult("ENERGY")
        input_unit = energy_result.GetComponentInfo("KINETIC").Unit
        conversion_factor = units.ConvertUnit(1., input_unit, "J", "Energy")
        energy_result.SelectComponents(["KINETIC"])
        for elementId in elementIds:
            # nodeIds = mesh.NodeIdsFromElementIds([elementId])
            element = mesh.ElementById(elementId)
            nodeIds = element.NodeIds
            deformation_x = deformationx.GetNodeValues(nodeIds)
            deformation_x_sum = math.fsum(deformation_x)
            deformation_y = deformationy.GetNodeValues(nodeIds)
            deformation_y_sum = math.fsum(deformation_y)
            deformation_z = deformationz.GetNodeValues(nodeIds)
            deformation_z_sum = math.fsum(deformation_z)
            deformation_total[elementId] = list(map(lambda x: math.sqrt(
                x[0]**2 + x[1]**2 + x[2]**2), zip(deformation_x, deformation_y, deformation_z)))
            deformation_total_sum = math.fsum(deformation_total[elementId])
            deformation_ratio_x[elementId] = deformation_x_sum / \
            deformation_ratio_y[elementId] = deformation_y_sum / \
            deformation_ratio_z[elementId] = deformation_z_sum / \
            energy_value = energy_result.GetElementValues([elementId], True)
            converted_energy_value = [
                value * conversion_factor for value in energy_value]
            KE_X[elementId] = [x * y for x,
                               y in zip(converted_energy_value, [deformation_ratio_x[elementId]])]
            KE_Y[elementId] = [x * y for x,
                               y in zip(converted_energy_value, [deformation_ratio_y[elementId]])]
            KE_Z[elementId] = [x * y for x,
                               y in zip(converted_energy_value, [deformation_ratio_z[elementId]])]
            KE[elementId] = [KE_X[elementId][0],
                             KE_Y[elementId][0], KE_Z[elementId][0]]
        fname = "D:\\KE_Mode_%i.txt" % mode
        with open(fname, 'w') as f:
            f.write('KINETIC ENERGY for MODE %i in X , Y , Z DIRECTIONS \n\n' % mode)
            f.write('ID: | Direction X | Direction Y | Direction Z \n\n')
            for k, v in KE.items():
                f.write(str(k) + ' , ' +
                        str(v[0]) + ' , ' + str(v[1]) + ' , ' + str(v[2]) + '\n')
        f.close()
        reader.Dispose()
    def modalKE():
        reader1 = Model.Analyses[0].GetResultsData()
        for mode in range(len(reader1.ListTimeFreq)):
    modalKE()
    Great solution @Pernelle Marone-Hitz .
    For general use:
    Note that the “mode” is not always the same as the result set. Depending on the type of solver used the results sets can also include the stability or also the negative freq. values. Look at the reader.ListTimeFreq property to see a list of the results set values if you are not sure.
    You can also use DPF to get the time frequency support for the results file which can be helpful to match the set number to the desired mode number
