How to identify different load vectors in a .sub file using DPF?
I am using the DPF cms matrices provider operator to read load vectors from a .sub file. The issue is that I have multiple load vectors, some of which have real and imaginary parts, but I haven't found a way to identify them. Is there a way to retrieve the names of the load vectors with DPF?
    Hi @Atacher, this would need further investigation. If this is about PyDPF, please open an issue on Github, mention the version that you are using and share a dummy model on which we can reproduce. If you are using DPF in Mechanical, please contact your local Ansys Support Provider and share the same information. Thanks
