Automation of Optislang using pyOptislang
I am trying to automate the running of Optislang file from the python environment using the pyOptislang.
My requirement is as follows
- Create an Optislang instance in python environment.
- Call and Run the Optislang file from the python environment.
I went through the user guide and the documentation from Ansys but not able to find the right documentation for this.
I tried modifying the existing scripts but I am getting errors.
So can you please support me by providing any example scripts for this requirement.
Hi @Bharathk,
thanks for reaching out to the forum.
First I want to point to the PyOptiSLang documentation optislang.docs.pyansys.com/.
Herein you will find the Getting Started and the User Guide.As very simple example to create and run an optiSLang instance is:
from ansys.optislang.core import Optislang osl = Optislang() osl_version = osl.osl_version_string print(osl_version) osl.dispose()
sometimes the subsequent optiSLang process needs a bit more time due to license acquisitions so that you might increase the initial timeout of default 20s to a larger time span
ini_timeout=60
:from ansys.optislang.core import Optislang osl = Optislang(ini_timeout=60) osl_version = osl.osl_version_string print(osl_version) osl.dispose()
To run a optiSLang project by the pythonic interface you'll need to open the project and start it:
from ansys.optislang.core import Optislang from ansys.optislang.core import examples project_path = examples.get_files("simple_calculator")[1][0] with Optislang(project_path=project_path) as osl: print(osl) osl.start()
Please reply your results or findings here.
Thanks,
Daniel0
