Is it possible to modify the user preferences under WB --> Tools --> Options using scripting?
You can use SetPreferenceValue(ObjectName,Value).
To find the right arguments, modify the setting manually and then check the XML files here: %AppData%\Ansys\v{version}\UserRegFiles_{number}
Most settings are stored in MainPreferences.XML
If you first reset everything to defaults, it will be easier to see what has changed.
You can use GetPreferenceValue(ObjectName) to test that you have the correct first argument before trying to figure out the second argument.
As an example, here is how to set WB --> Tools --> Options --> Appearance --> Text Color to the color red:SetPreferenceValue("GraphicsTextColor","255 0 0 0") # Red See: https://discuss.ansys.com/discussion/2860/how-to-change-background-text-color-in-wb-options-using-scripting/p1?new=1 for more details.
Setting options this way is not persistent. Closing Workbench and reopening will revert the settings. To make the settings persistent:Ansys.Core.Preference.Commands.SavePreferencesCommand.InvokeAndWait("")
