GridViewDropDownCell SelectedChanged event
1990chs
Member Posts: 47
I add a GridViewDropDownCell in GridView, and I want to do something after the dropdowncell selectchanged. But I am not find the revelation event in GridView.
I have try to use AfterCellEdit event, but it seems to work before the dropdowncell text changed.
So I want to know is there any event after dropdowncell selectchanged ?
BoltGridView = GridView() dropDownCell = Ansys.UI.Toolkit.GridViewDropDownCell() DropDownItems = [] DropDownItems.append(GridViewDropDownCell.GridViewDropDownItem('Shank')) DropDownItems.append(GridViewDropDownCell.GridViewDropDownItem('Screw')) dropDownCell.AddItems(System.Array[GridViewDropDownCell.GridViewDropDownItem](DropDownItems)) dropDownCell.Text = 'Shank' BoltGridView.Cells.SetCell(0, 0, dropDownCell)
This is solved.
From the args to get the StartRowIndex and type to do something after celledifdef DropDownChanged(self, sender, args): text = args.Value Cell = args.Cell RowIndex = Cell.StartRowIndex CellType = Cell.GetType() if CellType == self.DropDownCell: ExtAPI.Log.WriteMessage('Here') if text == 'Shank': self.Cells[RowIndex ,3].Text = '' self.Cells[RowIndex, 3].BackColor = Ansys.Utilities.Palette.LightGray self.Cells[RowIndex, 3].ReadOnly = True elif text == 'Screw': self.Cells[RowIndex, 3].BackColor = Ansys.Utilities.Palette.White self.Cells[RowIndex, 3].ReadOnly = False
You can use AfterCellEdit event, then check if the cell type is gridviewdropdowncell, then do something.
I don't find other eventdef DropDownChanged(self, sender, args): text = args.Value Cell = args.Cell CellType = Cell.GetType() if CellType == self.DropDownCell: # do something
