Plot contact pressure along deformed edge
I have a model as follows:
I'd like to plot the pressure variation for nodes in contact with the upper plate, along with the deformation profile.
Is this possible?
Credits should go to @Pierre Thieffry who created the example.
This can be achieved thanks to a Python Code object in Mechanical.
The logic behind is as follows:- Create a named selection to get the nodes of the profile:
- Note - when passed to the solver, the name of the named selection gets converted to capital letters.
- Use DPF to retrieve:
- *the contact pressure on the contact elements. This is done by selecting contact elements (type 172 in MAPDL) and extracting SMISC 5 to get the contact pressure.
- the node coordinates in deformed position for the profile
The abscissa and pressure values are then exported to a file in the user_files directory of the project
To plot the graph in Mechanical, several options are possible. One way is to use matplotlib to do this, but matplotlib is a CPython library whereas Python Code operates in IronPython. The trick is to write a python script in the user_files directory that will be executed by a CPython engine thanks to subprocess.
This script generates an image in the user_files directory
and Mechanical can then grab this image and add it to the Mechanical tree.
The code is a bit long so I will have to post this in several comments because of restrictions in the number of characters.
0 - Create a named selection to get the nodes of the profile:
Code up to helper functions:
def after_post(this, solution):# Do not edit this line """ Called after post processing. Keyword Arguments : this -- the datamodel object instance of the python code object you are currently editing in the tree solution -- Solution """ import math import os import mech_dpf import Ans.DataProcessing as dpf def get_user_files_directory(): user_files = '' if ExtAPI.Context == 'Project': user_files = GetUserFilesDirectory() elif ExtAPI.Context == 'Mechanical': import wbjn user_files = wbjn.ExecuteCommand(ExtAPI, "returnValue(GetUserFilesDirectory())") return user_files def findClosestNode(ref_coord,node_coords): mindist=1e31 minnode=-1 for nd,coord in node_coords.items(): dist=(ref_coord[0]-coord[0])**2+(ref_coord[1]-coord[1])**2+(ref_coord[2]-coord[2])**2 if dist<mindist: mindist=dist minnode=nd return minnode,mindist def getCurvilinearAbscissa(node_coords): local_node_coords={nid:coord for nid,coord in node_coords.items()} curv_absc=[] distances={} # Find maximum node location in Y direction ymax=-1e31 for nd,coord in local_node_coords.items(): if ymax<coord[1]: ymax=coord[1] # Filter nodes to those at Ymax - this will focus the results to the target metal sheet # where maximum pressure should occur to_remove=[] for ni,coord in local_node_coords.items(): if abs(coord[1]-ymax)>5e-3: to_remove.append(ni) for ni in to_remove: del local_node_coords[ni] # Now find chain of nodes from lowest X to largest X and # compute distance between nodes # find node with lowest X xmin=1e31 for nd,coord in local_node_coords.items(): if xmin>coord[0]: xmin=coord[0] ndmin=nd dist_idx=0 ref_coord=local_node_coords[ndmin] distances[dist_idx]=[ndmin,0.] dist_idx+=1 del local_node_coords[ndmin] # Now compute distance between nodes while len(local_node_coords.keys())>0: next_node,dist=findClosestNode(ref_coord,local_node_coords) distances[dist_idx]=[next_node,math.sqrt(dist)] ref_coord=node_coords[next_node] del local_node_coords[next_node] dist_idx+=1 curv_absc=[[distances[0][0],xmin]] # Create curvilinear abscissa by adding distances between nodes for i in range(1,max(distances.keys())+1): curv_absc.append([distances[i][0],curv_absc[-1][1]+distances[i][1]]) return curv_absc
Main part of the code (up to exporting the values in text format):
analysis=this.Parent.Parent mech_dpf.setExtAPI(ExtAPI) dataSource = dpf.DataSources(analysis.ResultFileName) # Retrieve scoping for all contact elements (type 172 in MAPDL) scoping_contact_elem=dpf.operators.scoping.on_property(requested_location='Elemental', property_name='mapdl_element_type',property_id=172,data_sources=dataSource) # Nodes from user named selection scoping_from_ns=dpf.operators.scoping.on_named_selection(requested_location='Nodal', named_selection_name='EDGEFORPLOT',data_sources=dataSource,int_inclusive=0) # Actual scopings elem_scoping=scoping_contact_elem.outputs.mesh_scoping.GetData() nodal_scoping=scoping_from_ns.outputs.mesh_scoping.GetData() # Operator to retrieve contact pressure (SMISC 5 for conta172 elements) cont_pres_elem= dpf.operators.result.mapdl.smisc(data_sources=dataSource,mesh_scoping=elem_scoping,item_index=5) cont_pres_nodal=dpf.operators.averaging.elemental_nodal_to_nodal_fc(cont_pres_elem) # Retrieve location of user_files directory for this project userFilesDir = get_user_files_directory() # Get pressure for all contact elements pressure_all_contacts=cont_pres_nodal.outputs.getfields_container()[0] # Rescope to nodes from selections pressure_selection_op=dpf.operators.scoping.rescope(fields=pressure_all_contacts, mesh_scoping=nodal_scoping) # Now this is the pressure field we want to plot over curvilinear abscissa pl=pressure_selection_op.outputs.getfields_as_field() # Get node ids and pressure values nodes=pl.ScopingIds values=pl.Data # Find node coordinates (in deformed position1) value_by_node={} node_coords={} rst_mesh=dpf.Model(dataSource).Mesh # Displacement field to update node coordinates with actual displacements u=dpf.operators.result.displacement(data_sources=dataSource,mesh_scoping=nodal_scoping) u_field=u.outputs.getfields_container()[0] for i in range(values.Count): val=values[i] value_by_node[nodes[i]]=val u_node=u_field.GetEntityDataById(nodes[i]) nd=rst_mesh.NodeById(nodes[i]) node_coords[nodes[i]]=[nd.X+u_node[0],nd.Y+u_node[1],nd.Z+u_node[2]] # Compute curvilinear abscissa curv_abs=getCurvilinearAbscissa(node_coords) # Reorder node coordinates on X values nids=[] xcoords=[] ycoords=[] for nid, coord in node_coords.items(): nids.append(nid) xcoords.append(coord[0]) ycoords.append(coord[1]) sorted_coords = zip(xcoords,ycoords) sorted_coords.sort() # Export pressure vs abscissa myPath = os.path.join(userFilesDir,'pressure_on_path_{0}.txt'.format(dp)) with open(myPath,'w') as f: f.write('Abscissa\tPressure}\n') for ca in curv_abs: f.write('{0:12.6e}\t{1:12.6e}\n'.format(ca[1],value_by_node[ca[0]])) # In same file, export node profile after deformation f.write('$\n') for row in sorted_coords: f.write('{0:12.6e}\t{1:12.6e}\n'.format(row[0],row[1]))
Code to create the plot with Matplotlib and add the image to Mechanical:
# Create plot using CPython code pngPath=os.path.join(userFilesDir,'pressure_on_path_{0}.png'.format(dp)) c_python_script=''' import os import matplotlib.pyplot as plt with open(r"'''+myPath+'''","r") as f: x_for_plot=[] y_for_plot=[] x_profile=[] y_profile=[] line=f.readline() line=f.readline() while not('$' in line): sp_line=line.strip("\\n").split("\\t") x_for_plot.append(float(sp_line[0])) y_for_plot.append(float(sp_line[1])) line=f.readline() line=f.readline() while line: sp_line=line.strip("\\n").split("\\t") x_profile.append(float(sp_line[0])) y_profile.append(float(sp_line[1])) line=f.readline() fig, ax = plt.subplots(figsize = (10, 5)) # using the twinx() for creating another # axes object for secondary y-Axis ax2 = ax.twinx() ax.plot(x_for_plot,y_for_plot,'b') ax2.plot(x_profile,y_profile,'r-') # giving labels to the axises ax.set_xlabel('abscissa') ax.set_ylabel('pressure',color='b') ax2.set_ylabel('y location of node',color='r') plt.tight_layout() myPath = r"'''+pngPath+'''" fig.savefig(myPath) ''' scriptPath = os.path.join(userFilesDir,'generate_plot.py'.format(dp)) with open(scriptPath,'w') as f: f.write(c_python_script) import sys,subprocess from System.Diagnostics import Process currentVersion=DataModel.Project.ProductVersion versionSplit=currentVersion.split(' ') root_folder='AWP_ROOT'+versionSplit[0][2:]+versionSplit[-1][-1] path1 = os.path.join( os.getenv(root_folder),r'commonfiles\CPython\3_7\winx64\Release\python', 'python.exe') # path to Mechanical's Python path2 = scriptPath # Argument for Python.exe call CMDARGS = '"{0}"'.format(path2) # Command for python exe including path to exe command = '"{0}"'.format(path1) ExtAPI.Log.WriteMessage(command) ExtAPI.Log.WriteMessage(CMDARGS) # Launch command with arguments proc = Process() proc.StartInfo.FileName = command proc.StartInfo.Arguments = CMDARGS proc.Start() proc.WaitForExit() # Add plot to Mechanical Tree with Transaction(): images=ExtAPI.DataModel.GetObjectsByType(Ansys.ACT.Automation.Mechanical.Image) try: for im in images: if im.Name=="Pressure on path": im.Delete() except: pass image = solution.AddImage(pngPath) image.Name="Pressure on path"
1
