How to select all bolt holes on all bodies and create washers, using space claim scripting
SK
SK Member Posts: 21
edited January 2024 in 3D Design
How to select all bolt holes on all bodies and create washers around all selected holes, equal to 2 times dia of that hole. And later I want to create fixed joints in mechanical between opposite washer faces of bolt holes. Can anyone help me the script as we have 100s of bolt to be modeled with the fixed joints.
  • Abhijith Rajan
    Abhijith Rajan Member, Employee Posts: 10
    Name Dropper First Anniversary First Answer First Comment
    edited March 2024
    Hey SK, You may check this script and make necessary modifications.
    myedges=Selection.Create(mybodies).ConvertToEdges().ConvertByShape(GeometryType.Circle)
    for e in myedges:
    if e.Items[0].Shape.Geometry.Radius > MM(5.39/2) and e.Items[0].Shape.Geometry.Radius < MM(5.4/2) : # you may edit here with your required Radius/Diameter Values
            selection = e
            direction = MoveImprintEdges.GetImprintDirection(e, e.ConvertToFaces().ConvertByShape(GeometryType.Plane), False)
            options = MoveImprintEdgeOptions()
            result = MoveImprintEdges.Execute(selection, direction, MM(-1.64), options) # this value changes the washer dia
    myreqfaces=List IDesignFace
    myfaces=Selection. Create(GetRootPart().GetAllBodies()).ConvertToFaces().ConvertByShape(GeometryType.Plane)
    for f in myfaces:
    myedges=f.ConvertToEdges()
    if myedges.Count==2:
    myreqfaces.Add(f.Items[0])
    Selection.Create(myreqfaces).CreateAGroup("MyReqFaces")
  • Abhijith Rajan
    edited March 2024
    Check out this sample code for creating the washer splits. You may make the necessary changes by changing the Hole Diameter and Washer Diameter values. Note that this script would create the washer split in both side of the hole
    for e in myedges:
            selection = e
    for f in myfaces:
  • SK
    SK Member Posts: 21
    Many thanks. Can you please tell me where to declare mybodies as I'm getting an error saying "name 'mybodies' is not defined"
