How can I create Mesh scoping for individual bodies in an assembly of a MAPDL result file using DPF?
Ayush Kumar
Member, Moderator, Employee Posts: 482
Part IDs can't be scoped directly. We need to scope based on the
mapdl_element_type
property and and then split it further usingmat
property. Example below:import os from ansys.dpf import core as dpf from ansys.dpf.core.plotter import DpfPlotter out_path = r"\PATH\TO\RST" rst_path = os.path.join(out_path, "file.rst") ds = dpf.DataSources(rst_path) model = dpf.Model(ds) mesh = model.metadata.meshed_region """ # SHELL181 """ scope_op = dpf.operators.scoping.on_property(requested_location="Elemental", property_name="mapdl_element_type", property_id=181, data_sources=ds) scoping = scope_op.outputs.mesh_scoping() print(scoping) mesh_scoping_op = dpf.operators.scoping.split_on_property_type(mesh_scoping=scoping, mesh=mesh, label1="mat") mesh_scoping = mesh_scoping_op.outputs.mesh_scoping.get_data() print(mesh_scoping)
