The workbench Geometry coordinate datas unit
1990chs
1990chs Member Posts: 47
edited January 2024 in General Language Questions
The workbench Geometry length unit is mm. But when I use ironPython API to get geometry Centroid, the result unit seems m and the mesh node.X seems also m.
So how to get the Centroid length unit and MeshData units ?
analysis = Model.Analyses[0]
face = analysis.GeoData.GeoEntityById(44)
faceCenter = face.Centroid
# The Centroid unit seems m, but the workbench geometry model is mm
modelMesh = analysis.MeshData
node = modelMesh.NodeById(1)
node.X
# The node coordinate unit seems m
I am confused by the ironPython API results.
So is there any description about the units or how to get these units ?
Best Answers
  • 1990chs
    Thinks, if I want to get the rstfile mesh length unit. How to get it?
    I find a way but I am not sure it is right or not.
    reader = analysis.GetResultsData()
    rstMesh = reader.CreateMeshData()
    # the rstMesh don't have unit information, try to  use local unit.
    Loc = reader.GetResult('LOC')
    Loc.SelectComponents(['X'])
     LocUnit = Loc.GetComponentInfo('X').Unit
    # get the rstMesh node
    Node = rstMesh.NodeById(NodeId)
    Node.X    # get Node X  coordinate
  • 1990chs
    @Mike.Thompson
    What's " the results file unit system specified in either the solution or solution information object in Mechanical" ?
    I forget which object it is, but one of them has a property listing the unit system of the results file.
  • 1990chs
    edited January 2024
    @Mike.Thompson
    I found two API in solution.
    solution.ResultFileUnitSystem
    #>>ConsistentNMM
    solution.SolutionUnitSystem
    #>>ConsistentNMM
    mm, kg, N, C, s, mV, mA
    (nmm)
