Export a CSV with Element ID and nodal averaged stress of the element face in WB LS-Dyna.
Ayush Kumar
Member, Moderator, Employee Posts: 494
DPF can be used in Python-Code object to export a CSV
After Post
for the above mentioned request.
Pre-requisites:- Named Selection of all the Element faces.
- 2022R2 and above
Copy the following in the
Script
part of the Python Code object:def after_post(this, solution):# Do not edit this line import os import json import mech_dpf import Ans.DataProcessing as dpf mesh = ExtAPI.DataModel.MeshDataByName("Global") ns_name = this.GetCustomPropertyByPath("Named Selection/Name").Value element = ExtAPI.DataModel.GetObjectsByName(ns_name)[0] element_face_indices = element.ElementFaceIndices el_face_nodes = {} all_nodes = [] ElementFaceWrapper = Ansys.ACT.Common.Mesh.ElementFaceWrapper for id, index in zip(element.Ids, element_face_indices): el_face = ElementFaceWrapper(mesh, mesh.ElementById(id), index) nids = el_face.NodeIds el_face_nodes.update({id: nids}) all_nodes += nids mech_dpf.setExtAPI(ExtAPI) analysis = Model.Analyses[0] d3plot_path = os.path.join(analysis.WorkingDir, "d3plot") act_units_path = os.path.join(analysis.WorkingDir, "file.actunits") ds = dpf.DataSources() ds.SetResultFilePath(d3plot_path, "d3plot") ds.AddFilePath(act_units_path, "actunits") model = dpf.Model(ds) ts = dpf.Scoping() ts.Ids = [int(this.GetCustomPropertyByPath("Time History Results/Result at Set Number").Value)] ms = dpf.Scoping() ms.Ids = list(set(all_nodes)) sx = dpf.operators.result.stress_X(time_scoping=ts, requested_location=dpf.locations.nodal, data_sources=ds) sx_f = sx.outputs.fields_container.GetData()[0] file_path = os.path.join(analysis.WorkingDir, "el_face_avg.csv") if os.path.isfile(file_path): # if exists, delete the file os.remove(file_path) with open(file_path, 'w') as file: file.write("EID; Element Face Average") file.write("\n") el_face_print = el_face_nodes.copy() for eid, nids in el_face_nodes.iteritems(): sx_avg = sum([sx_f.GetEntityDataById(nid)[0] for nid in nids]) / len(nids) el_face_print.update({eid: [nids, sx_avg]}) file.write("{0}".format(eid)) file.write("; ") file.write("{0}".format(sx_avg)) file.write("\n") return
Replace the
reload_props
function with the following inProperty Provider
:def reload_props(): provider = Provider() group_one = provider.AddGroup("Time History Results") SetNum = group_one.AddProperty("Result at Set Number", Control.Double) SetNum.Value = 1 # Default set value group_two = provider.AddGroup("Named Selection") ns = group_two.AddProperty("Name", Control.Expression) this.PropertyProvider = provider
