How can I export results summary worksheet in Mechanical?
Tom David
Member, Employee Posts: 7
How can I export the result summary worksheet to a text file through python ACT?
To my knowledge, access to worksheet is not yet exposed in ACT scripting. A possible workaround is to use jscript. The below code uses unsupported and undocumented commands, use at your own risk:
analysis = ExtAPI.DataModel.Project.Model.Analyses[0] # First analysis analysis.Solution.Activate() #Activating solution ExtAPI.Application.ScriptByName("jscript").ExecuteCommand('WB.PreferenceMgr.Preference("PID_Open_Excel") = 0;') # Blocking Excel from opening after export ExtAPI.Application.ScriptByName("jscript").ExecuteCommand('DS.Script.toggleWorksheetVisibilityInContexMenu();') # Turn on worksheet mode with "Result Summary" section selected ExtAPI.Application.ScriptByName("jscript").ExecuteCommand('DS.Script.doExportWorksheetToTextFile("D:/WorsheetResult.txt");') # Exporting result, replace path in this line
If you want to execute this functionality from WB-project page, the way would be the following:
my_system=GetSystem(Name="SYS") my_model = my_system.GetContainer(ComponentName="Model") my_model.Edit(Hidden=True) cmd="""analysis = ExtAPI.DataModel.Project.Model.Analyses[0] analysis.Solution.Activate()""" my_model.SendCommand(Language="Python",Command=cmd) cmd2="""DS = WB.AppletList.Applet("DSApplet").App; WB.PreferenceMgr.Preference("PID_Open_Excel") = 0; DS.Script.toggleWorksheetVisibilityInContexMenu();""" my_model.SendCommand(Language="Javascript", Command=cmd2) cmd3="""DS = WB.AppletList.Applet("DSApplet").App; var MyWait = DS.Script.AnsObjectFactory.CreateDispatchObject("WBControls.WBTestHelper.211"); MyWait.Wait(2000); DS.Script.doExportWorksheetToTextFile("D:////WorsheetResult.txt");""" my_model.SendCommand(Language="Javascript", Command=cmd3) my_model.Exit()
