How to create beam bending moment (BMD) and shear force diagram (SFD) using PyMAPDL and PyDPF
Vishnu
edited February 2024 in Structures
shear force and bending moment diagram example below uses BEAM188 elements .
example uses pyMAPDL to run the simulation
Pydpf to extract result
matplotlib to plot the SF and BM diagrams
You can alter the beam SECTYPE,SECDATA, fix_location and force location as input arguments of the function
  • Vishnu
    Inputs and import statements
    #Import statements
    import numpy as np
    from matplotlib.cm import ScalarMappable
    from matplotlib.colors import Normalize
    from matplotlib import ticker
    run_location=r"D:\apdl\test\4"
    nproc=4
    override=True
    mapdl = launch_mapdl(run_location=run_location, nproc=nproc, override=override)
    Creation of model using pyMAPDL
    def create_model_setup(SECDATA,
                           BEAM_LENGTH,
                           LINE_DIV,
                           LENGTH_DIV,
                           YM,
                           MU,
                           SECTYPE,
                           SECSUBTYPE):
        mapdl.clear("All")
        mapdl.prep7()
        mapdl.et('', 'BEAM188')
        mapdl.mp(lab='EX', mat='1', c0='%s'%(YM))
        mapdl.mp(lab='PRXY', mat='1', c0='%s'%(MU))
        mapdl.sectype(secid='1', type_='BEAM', subtype='%s'%(SECTYPE))
        mapdl.secdata(tuple(SECDATA))
        mapdl.seccontrol(1E15,1E15)
        mapdl.k(npt='1', x='0', y='0', z='0')
        mapdl.k(npt='2', x='%s'%(BEAM_LENGTH), y='0', z='0')
        mapdl.l(p1='1', p2='2', ndiv='%s'%(LINE_DIV))
        mapdl.lesize(nl1='ALL', size='', angsiz='', ndiv='%s'%(LENGTH_DIV))
        mapdl.lmesh(nl1='ALL')
    Adding Loads and Bc and Solving them
    def run_simulation(fix_loc,
                       pin_loc,
                       concentrated_loc,
                       concentrated_force,
                       distributed_loc,
                       distributed_force,
                       elem_plot_flag):
        mapdl.solution()
        mapdl.ddele(node='ALL', lab='ALL')
        mapdl.fdele(node='ALL', lab='ALL')
        mapdl.sfedele(elem='ALL', lkey='ALL', lab='ALL')
        for fix_lo in fix_loc:
            fix_node = mapdl.queries.node(fix_lo[0], fix_lo[1], fix_lo[2])
            mapdl.d(node='%s'%(fix_node), lab='ALL', value='0')
        for pin_lo in pin_loc:
            pin_node = mapdl.queries.node(pin_lo[0], pin_lo[1], pin_lo[2])
            mapdl.d(node='%s'%(pin_node), lab='UX', value='0')
            mapdl.d(node='%s'%(pin_node), lab='UY', value='0')
            mapdl.d(node='%s'%(pin_node), lab='UZ', value='0')
            mapdl.d(node='%s'%(pin_node), lab='ROTY', value='0')
            mapdl.d(node='%s'%(pin_node), lab='ROTZ', value='0')
        for count, force_lo in enumerate(concentrated_loc):
            force_node = mapdl.queries.node(force_lo[0], force_lo[1], force_lo[2])
            mapdl.f(node='%s'%(force_node), lab='FY', value=concentrated_force[count])
        for count, force_lo in enumerate(distributed_loc):
            mapdl.esel(type_='S', item='CENT', comp='X', vmin=force_lo[0], vmax=force_lo[1])
            mapdl.sfbeam(elem='ALL', lkey='2', lab='PRES', vali=distributed_force[count])
            mapdl.allsel(labt='ALL', entity='ALL')
        mapdl.outres(item='ALL', freq='ALL')
        if elem_plot_flag == True:
            mapdl.eplot(plot_bc=True, bc_labels=["UX", "UY", "UZ", "FX", "FY", "FZ"], plot_bc_labels=True)
        mapdl.solve()
        mapdl.save(fname='test', ext='db')
    Extracting shear force and bending moments using DPF and plot using matplotlib
    def plot_bending_moment_shear_force(rstpath,
                                        smiscI,
                                        smiscJ,
                                        plotname):
        # data source
        my_data_sources = dpf.DataSources(rstpath)
        # model
        my_model = dpf.Model(rstpath)
        # mesh
        my_mesh = my_model.metadata.meshed_region
        # Get result operator
        result_operator = dpf.operators.result.__getattribute__("smisc")
        result_field_container = result_operator(
            time_scoping=[1], data_sources=my_data_sources, mesh=my_mesh, item_index=smiscI
        ).outputs.fields_container.get_data()
        # First Field usually field corresponding to first time scoping
        resultfield = result_field_container[0]
        element_ids = resultfield.scoping.ids
        i_nodes_coordinates = [my_mesh.elements.element_by_id(
            x).nodes[1].coordinates[0] for x in element_ids]
        BMY_T_I = resultfield.data_as_list
            time_scoping=[1], data_sources=my_data_sources, mesh=my_mesh, item_index=smiscJ
        j_nodes_coordinates = [my_mesh.elements.element_by_id(
        BMY_T_J = resultfield.data_as_list
        # Assuming i_nodes_coordinates, j_nodes_coordinates, BMY_T_I, BMY_T_J are defined
        x = np.concatenate((i_nodes_coordinates, j_nodes_coordinates))
        y = np.concatenate((BMY_T_I, BMY_T_J))
        # Create a colormap
        cmap = plt.get_cmap('viridis')
        norm = Normalize(vmin=np.min(y), vmax=np.max(y))
        # Create a ScalarMappable
        sm = ScalarMappable(cmap=cmap, norm=norm)
        sm.set_array([])
        # Create the bar chart
        fig, ax = plt.subplots(figsize=(15, 5))  # Adjust the figure size
        ax.bar(x, y, color=cmap(norm(y)))
        ax.set_xlabel('X_distance')
        ax.set_title(plotname+' Diagram')
        # Set y-axis limits
        ax.set_ylim([np.min(y), np.max(y)])
        # Create an array of 10 evenly spaced values between min(y) and max(y)
        ticks = np.linspace(np.min(y), np.max(y), 10)
        # Add a colorbar with specific ticks
        cbar = fig.colorbar(sm, ax=ax, ticks=ticks)
        cbar.set_label(plotname)
        # Format the colorbar tick labels to have two decimal places
        cbar.formatter = ticker.FuncFormatter(lambda x, pos: '{:.4f}'.format(x))
        cbar.update_ticks()
        plt.show()
    Function calls Below
    ### Call the defined functions####
    # create model
    create_model_setup(
        SECDATA=[5, 8, 2],  # SECDATA = [BEAM_RADIUS,CIRCUM_DIV,RADIAL_DIV]
        BEAM_LENGTH=100,
        LINE_DIV=50,
        LENGTH_DIV=1,
        YM=2E8,
        MU=0.3,
        SECTYPE="CSOLID",
        SECSUBTYPE="CIRBEAM",
    #Run simulation
    run_simulation(
        fix_loc=[[10, 0, 0], [90, 0, 0]],
        pin_loc=[[50, 0, 0]],
        concentrated_loc = [[30, 0, 0], [80, 0, 0],[100, 0, 0]],
        concentrated_force = [1000, 500,500],
        distributed_loc=[[0,100]],
        distributed_force = [1000],
        elem_plot_flag = True
    # Bending Moment diagram
        rstpath=os.path.join(run_location, "file.rst"),
        smiscI=32,
        smiscJ=37,
        plotname="Bending Moment"
    # Shear Force diagram
        rstpath=r"D:\apdl\test\4\file.rst",
        smiscI=6,
        smiscJ=19,
        plotname="Shear Force"
    mapdl.exit()
  • Vishnu
  • Vishnu
  • deepak
    deepak Member Posts: 2
    Second Anniversary First Comment
    i am getting error while running above code.
    The operator SMISC doesn't exist in the registry. Check its spelling in the documentation or verify its availability in your loaded plugins. The current available operator names can be accessed using 'available_operator_names' method."
    how to rectify it?
    thanks
  • Vishnu
    edited May 2024
    @deepak
    In recent releases its
    dpf.operators.result.smisc
    in earlier releases its
    dpf.operators.result.mapdl.smisc
    Please check these
