Run a ansys using pyfluent
hello everyone, I would to run an ANSYS project using pyfluent (I'll do all the work in ansys , ), is this possible ?I or I should re-write the project line by line in pyfluent ?
thank you in advance
  • James Derrick
    James Derrick Administrator, Employee Posts: 314
    admin
    Hi @Jinane Radi, it's a bit unclear what you're asking here. Are you asking if you can build a Fluent project in PyFluent? Is that correct?
  • Jinane Radi
    Jinane Radi Member Posts: 5
    Hello Mr.@James Derrick ,
    if, for example, I create a complete project with ansys workbensh, from inserting the geometry to obtaining the results..
    Is it possible to run this already established project using pyansys?
