Fluent Post Process Plot X-Y Dimension vs Contour
Snowfiend
Snowfiend Member Posts: 1 **
edited January 2024 in Fluids
Is there a way to graphically plot X-Y position against a contour graphic plot? I cant seem to add the two together, I have tried scene overlap but this does not allow the two different types of results to interact.
I am wondering if there is a function that can produce the above image accurately, or is this usually done manually as I have done.
Ideally, I have created a 'line' surface, if I could add dimensions to that line, that would be perfect.
Thank you in advance
  • Chris Harrold
    admin
    Thank you @Sean Pearson
    @Snowfiend - given the answer from Sean, it explains why this may have lingered so long. The developer portal and forums are for scripting and developer related questions. You can post this over in the support forum (forum.ansys.com) and they can assist.
