I am using Pymechanical and I keep getting this error
_MultiThreadedRendezvous: <_MultiThreadedRendezvous of RPC that terminated with:
status = StatusCode.RESOURCE_EXHAUSTED
details = "to-be-sent trailing metadata size exceeds peer limit"
debug_error_string = "UNKNOWN:Error received from peer {grpc_message:"to-be-sent trailing metadata size exceeds peer limit", grpc_status:8, created_time:"2024-01-30T14:31:15.8037186+00:00"}"
My Code:
nodes = mechanical.run_python_script("""
import json
mesh_data = ExtAPI.DataModel.Project.Model.Analyses[0].MeshData
output_faceMesh = mesh_data.MeshRegionById(26) #26 is the Id of the surface
input_faceMesh = mesh_data.MeshRegionById(28) #28 is the Id of the surface
output_nodes = output_faceMesh.NodeIds
input_nodes = input_faceMesh.NodeIds
nodes = {'output_nodes' : output_nodes,
'input_nodes' : input_nodes
json.dumps(nodes)
I suspect this is data transfer limit problem in the gRPC framework in Pymechanical.
Particularly because I am dumping json which is larger in size compared to the protocol buffers.
If this is the case, is there a better way to extract the data?
If not, what then is the problem?
Thank you in advance
