Add selected solution item to the SelectionManager
Hi Team,
I would like to loop over all the solution elements I have selected (like stress, strain or else) in order to create some animations from them.
However selection = ExtAPI.SelectionManager.CurrentSelection won't work, selection array is empty.
Should I tell to the Selection manager what kind of object type I want to select?
I must say that the documentation is pretty poor (and extremely slow) regarding the ExtAPI. The only good guidelines are contained in that forum.
Thanks by advance for your answer
    The selection manager is for the graphics window selection.
    What you want is Tree.ActiveObjects for getting the object active in the tree.
    I highly recommend going through training on ANSYS Learning Hub before trying to understand the documentation.
  • flux
    flux Member Posts: 4
    Thanks for your quick answer , I will have a look at it.
