OSError While trying to output UY component data using PyDPF
amusthaf
amusthaf Member Posts: 16
I am trying to output UY component data for particular nodes at all time_frequencies. But I am stuck up with this error:
It would be really helpful if I can have any leads on this issue.
  • amusthaf
    generally, time_ids = [1,2,3,4,5,6,7,8,9,10,11,12], since I have 12 number of sets.
    When I try to scope all the 12 number of sets, I am encountering this OSError. But, when I reduce the length of time_ids, i.e., time_ids = [1,2,3,4,5,6,7,8], it is working for me. Still, I have not completely understood what the problem can be. If anybody have any ideas, please help.
    This might be related to a bug that was fixed in 2024R1. Can you please try again with this version of the server? Thanks
  • Ayush Kumar
    @amusthaf
    As @Pernelle Marone-Hitz mentioned this is indeed a bug on the server side. This should help:
    Add either of these lines (prefer 241 if you have WB 241 installed) at the top of your script (after ansys.dpf.core module import).
    dpf.start_local_server(ansys_path=r"C:\Program Files\ANSYS Inc\v232")
    dpf.start_local_server(ansys_path=r"C:\Program Files\ANSYS Inc\v241")
