C# DPF API Example
Ayush Kumar
Member, Moderator, Employee Posts: 497
How to Use this example project
Windows:
If DPF was installed as part of a normal Ansys Software installation, the
required .dll files are available for running the DPF capabilitiesyou can create a .bat file to laucnh Visual studio with these lines:
set AWP_ROOTDV_DEV=C:\Program Files\Ansys Inc\v241
set PATH=%AWP_ROOTDV_DEV%\aisol\bin\winx64;%PATH%start "" "C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\Common7\IDE\devenv.exe"
and then load the
dpf_csharp_client.csproj
<Project Sdk="Microsoft.NET.Sdk"> <PropertyGroup> <OutputType>Exe</OutputType> <TargetFramework>net472</TargetFramework> <AutoGenerateBindingRedirects>true</AutoGenerateBindingRedirects> <Platforms>AnyCPU;x64</Platforms> </PropertyGroup> <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|AnyCPU'"> <PlatformTarget>x64</PlatformTarget> <OutputPath>$(AWP_ROOTDV_DEV)\aisol\bin\winx64\</OutputPath> <WarningLevel>0</WarningLevel> </PropertyGroup> <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'"> <PlatformTarget>x64</PlatformTarget> <OutputPath>$(AWP_ROOTDV_DEV)\aisol\bin\winx64\</OutputPath> <WarningLevel>0</WarningLevel> <DefineConstants>DEBUG;TRACE</DefineConstants> </PropertyGroup> <ItemGroup> <Reference Include="Ans_Dpf_FEMutils_dll_cs"> <HintPath>$(AWP_ROOTDV_DEV)\aisol\bin\winx64\Ans_Dpf_FEMutils_dll_cs.dll</HintPath> </Reference> <Reference Include="Ans_Dpf_Native_dll_cs"> <HintPath>$(AWP_ROOTDV_DEV)\aisol\bin\winx64\Ans_Dpf_Native_dll_cs.dll</HintPath> </Reference> <Reference Include="CS_DataProcessing"> <HintPath>$(AWP_ROOTDV_DEV)\aisol\bin\winx64\CS_DataProcessing.dll</HintPath> </Reference> </ItemGroup> </Project>
Program.cs
using System; using System.IO; using Ans.DataProcessing; namespace dpf_csharp_client { class Program { static void Main(string[] args) { /* this will only work on Windows */ Environment.CurrentDirectory = Environment.GetEnvironmentVariable("AWP_ROOTDV_DEV"); DataProcessingCore.InitializationWithContext(1, Environment.CurrentDirectory .ToString()+ "\\dpf\\utilities\\DpfCoreStandalone.xml"); /* DataProcessingCore.Initialization(); */ /* read displacements from an rst file */ var op = new Ans.DataProcessing.operators.result.displacement(); op.inputs.data_sources.Connect(new DataSources("C:\\temp\\file.rst")); var fields = op.outputs.getfields_container(); var field = fields[0]; /* read a mesh from an rst file */ var op2 = new Ans.DataProcessing.operators.mesh.mesh_provider(); op2.inputs.data_sources.Connect(new DataSources("C:\\temp\\file.rst")); var mesh = op2.outputs.getmesh(); var nrmop = new Ans.DataProcessing.operators.math.norm_fc(fields); fields = nrmop.outputs.getfields_container(); field = fields[0]; } } }
launchSettings.json
{ "profiles": { "dpf_csharp_client": { "commandName": "Project", "workingDirectory": "$(AWP_ROOTDV_DEV)\\aisol\\Bin\\winx64" } } }
Set-up the above mentioned files in the following folder structure:
