How do I extract Max. and Min over Time for different Cases in Mechanical LSDyna using DPF?
This is a Python Result Solution in 2024R1:
def post_started(sender, analysis):# Do not edit this line define_dpf_workflow(analysis) def define_dpf_workflow(analysis): import os import mech_dpf import Ans.DataProcessing as dpf mech_dpf.setExtAPI(ExtAPI) analysis = Model.Analyses[0] case_nr = this.GetCustomPropertyByPath("Cases/Case Number").ValueString ds = dpf.DataSources() d3plot_path = os.path.join(analysis.WorkingDir, "case%s.d3plot" % case_nr) act_units_file = os.path.join(analysis.WorkingDir, "file.actunits") ds.SetResultFilePath(d3plot_path, 'd3plot') ds.AddFilePath(act_units_file, "actunits") streams = dpf.operators.metadata.streams_provider(data_sources=ds) stream = streams.outputs.getstreams_container() time_freq_support = dpf.operators.metadata.time_freq_provider() time_freq_support.inputs.streams_container.Connect(stream) n_sets = time_freq_support.outputs.time_freq_support.GetData().NumberSets time_steps = range(1, n_sets + 1) timeScop = dpf.Scoping() timeScop.Ids = time_steps seqv = dpf.operators.result.stress_von_mises() seqv.inputs.requested_location.Connect(dpf.locations.nodal) seqv.inputs.time_scoping.Connect(timeScop) seqv.inputs.streams_container.Connect(stream) seqv_fc = seqv.outputs.fields_container.GetData() seqv_min_max = dpf.operators.min_max.min_max_over_time_by_entity(fields_container=seqv_fc) seqv_max_time = seqv_min_max.outputs.getmax()[0] seqv_min_time = seqv_min_max.outputs.getmin()[0] if this.GetCustomPropertyByPath("Min Max over Time/Type").ValueString == "Maximum over Time": out_f = seqv_max_time elif this.GetCustomPropertyByPath("Min Max over Time/Type").ValueString == "Minimum over Time": out_f = seqv_min_time out_op = dpf.operators.utility.forward_field() out_op.inputs.field.Connect(out_f) stream.ReleaseHandles() dpf_workflow = dpf.Workflow() dpf_workflow.Add(out_op) dpf_workflow.SetOutputContour(out_op) dpf_workflow.Record('wf_id', False) this.WorkflowId = dpf_workflow.GetRecordedId()
def reload_props(): this.PropertyProvider = None # Create the property instance provider = Provider() # Create a new group named Cases group = provider.AddGroup("Cases") # Add an options property to the group options_prop = group.AddProperty("Case Number", Control.Options) solver = Model.Analyses[0].Solver n_cases = solver.Properties['Step Controls/NCases'].Value n_cases_opt = {} for case in range(1, int(n_cases) + 1): n_cases_opt.update({case: "%s" % case}) # Add a couple options to the options property. options_prop.Options = n_cases_opt options_prop.Value = 1 group = provider.AddGroup("Min Max over Time") # Add an options property to the second group options_prop = group.AddProperty("Type", Control.Options) # Add a couple options to the options property. options_prop.Options = {1 : "Maximum over Time", 2 : "Minimum over Time"} options_prop.Value = "Maximum over Time" this.PropertyProvider = provider
