Animate_mode is not working as expected
Hi
I ve been recently trying to use functionality of Animate_mode, but tbh i found weird how it works, its producing animation as expected, but only contour plot is changing during animation and mesh is not deformed by field. This should look like that, or i am doing sth wrong?
i used example provided in HELP with added "deform_scale_factor=10"
import ansys.dpf.core as dpf
model = dpf.Model(examples.download_modal_frame())
disp = model.results.displacement.on_all_time_freqs.eval()
#Creates an animation from a modal result.
from ansys.dpf.core import animation
animation.animate_mode(disp, mode_number=1, save_as="tmp.gif",deform_scale_factor=10)
  • M
    M Member, Employee Posts: 256
    Known issue. You can check in on progress by checking the github link for the issue: https://github.com/ansys/pydpf-core/issues/1032
  • kacper.J
    kacper.J Member Posts: 4
    thank you M for that response, do you know when possible solution of that issue will be published ?
  • Landon Mitchell Kanner
    Is there any workaround for this issue? Such as converting the displacement to the time domain?
    @Ayush Kumar @AKD-Scripting-Team
  • Ayush Kumar
    Ayush Kumar Member, Moderator, Employee Posts: 508
    A pull request exists for the Fix, not aware of any workaround.
    https://github.com/ansys/pydpf-core/pull/1696
  • M
    edited August 2024
    This could be done with the python work around I created for a pymapdl example.
    Basically, create a lot of images, use imagio to animate.
    import os, webbrowser
    import imageio.v2 as imageio
    from IPython.display import display, clear_output
    subfolder = 'figs'
    if subfolder not in os.listdir():
        os.mkdir(subfolder)
    picList = []
    for ctr in range(10):
        fileName = os.path.join(jobLocation, subfolder , 'file' + str(ctr) + '.jpg')
        picList.append(fileName)
        result.plot_nodal_displacement(0, cpos='xy',off_screen=True,displacement_factor  = ctr*1000,show_displacement = True, show_edges=True, screenshot=fileName)
        clear_output()
    myfile = 'myAnime.mp4'
    aniSave = os.path.join(jobLocation, myfile)
    images = []
    for filename in picList:
        images.append(imageio.imread(filename))
    imageio.mimsave(aniSave, images)
    writer = imageio.get_writer(myfile, fps=40)
    for im in picList:
        writer.append_data(imageio.imread(im))
    writer.close()
    import webbrowser
    webbrowser.open(aniSave)
