Get the harmonic results with DPF and compare them to the Mechanical results. Uses an operator to combine the real+img components together to get the amplitude results (same as mechanical results)
FYI the code snippet from the model attached in original post is below:
#----------------------------------------------------------------------------------------- #Keep this suppressed. #Use this code in the scripting console #----------------------------------------------------------------------------------------- #Snippet will extract the results of the harmonic analysis with complex (real and img) results. #It will convert it to an amplitude, and compare this against post processing objects in mechanical. #This general process is based on a single node and single freq. for purposes of comparison to Mech. results. #The mesh scoping and time/freq. scoping of the operators can be changed to make it more general across the mesh and freq. domains. #----------------------------------------------------------------------------------------- #User Inputs: FreqSet = 5 #Frequency Set you want to get results for NsName = "Measure Node" #Named Selection exact text name #----------------------------------------------------------------------------------------- #General Import Stuff import mech_dpf import Ans.DataProcessing as dpf mech_dpf.setExtAPI(ExtAPI) analysis=Model.Analyses[0] dataSource = dpf.DataSources(analysis.ResultFileName) #Get the node Id you want to measure MeasureNdId = ExtAPI.DataModel.GetObjectsByName(NsName)[0].Ids[0] MeshScoping = dpf.MeshScopingFactory.NodalScoping([MeasureNdId]) print "Named Selection = '%s' with Node Id = %s" % (NsName, MeasureNdId) #Get the time freq. support for the results file (set, step, substep, freq. info) TFSOp = dpf.operators.metadata.time_freq_provider() TFSOp.inputs.data_sources.Connect(dataSource) TFS = TFSOp.outputs.time_freq_support.GetData() #Make a frequency scoping to know what freq. to export FreqScoping = dpf.TimeFreqScopingFactory.ScopingByStepAndSubstep(1,FreqSet,TFS) print "Frequency for results: %s [Hz]" % TFS.GetTimeFreq(FreqSet-1) #subtract 1 for a zero-based index #Get the displacement via dpf operator u = dpf.operators.result.displacement() u.inputs.data_sources.Connect(dataSource) u.inputs.mesh_scoping.Connect(MeshScoping) u.inputs.time_scoping.Connect(FreqScoping) uFC = u.outputs.fields_container.GetData() #Convert the complex result (real and img.) to an amplitude result #This will be consistant with mechanical AmpOp = dpf.operators.math.amplitude_fc() # operator instantiation AmpOp.inputs.fields_container.Connect(uFC) AmpFC = AmpOp.outputs.fields_container.GetData() #print AmpFC print "DPF Results for Node: %s [X,Y,Z] with units=%s" % (MeasureNdId, AmpFC[0].Unit) #print AmpFC[0].Data DpfValues = [Quantity(V, AmpFC[0].Unit) for V in AmpFC[0].Data] print DpfValues CheckObjIds = [51,54,62] CheckObjs = [ExtAPI.DataModel.GetObjectById(Id) for Id in CheckObjIds] for Obj in CheckObjs: Obj.SetNumber=FreqSet Obj.Parent.EvaluateAllResults() for Obj in CheckObjs: Obj.RenameBasedOnDefinition() MechValues = [abs(Obj.Maximum) for Obj in CheckObjs] Diffs = [((MechValues[i] - DpfValues[i]) / MechValues[i]) * 100. for i in range(3)] print "% Difference in the dpf values to Mechanical object values" print Diffs
