I want to map some data onto a mesh using DPF's mapping workflow. How can I do this?
Here's a sample code to use in a Python Code.
To insert commands just prior to the ANSYS SOLVE command, use solver_input_file.WriteLine("!Your command") Global Helpers: this -- the datamodel object instance of the python code object you are currently editing in the tree solver_input_file -- file stream that allows you to inject commands into the solver input file solver_data -- data stucture that allows you to access information from the model such as current step, contact pair ids, etc. """ # To access properties created using the Property Provider, please use the following command. # this.GetCustomPropertyByPath("your_property_group_name/your_property_name") # To access scoping properties use the following to access geometry scoping and named selection respectively: # this.GetCustomPropertyByPath("your_property_group_name/your_property_name/Geometry Selection") # this.GetCustomPropertyByPath("your_property_group_name/your_property_name/Named Selection") import mech_dpf import Ans.DataProcessing as dpf import os def GetDpfMeshFromMechMesh(ExtAPI, BodyIds=None): """ Get a DPF mesh region from a mechanical mesh Args: BodyIds (list of int) (optional): Ids for GeoBodies to get region Returns: dpf.MeshedRegion """ MechMesh=ExtAPI.DataModel.MeshDataByName("Global") #Get the node ids if BodyIds!=None: NdIds=set() for Id in BodyIds: Region=MechMesh.MeshRegionById(Id) NdIds.update(Region.NodeIds) else: NdIds=set(MechMesh.NodeIds) #convet to elem. ids. ElIds=MechMesh.ElementIdsFromNodeIds(NdIds) #Convert to Dpf MeshRegion DpfMesh=dpf.MeshedRegion(0,0) NdIndexByIds={} i=0 for NdId in NdIds: N=MechMesh.NodeById(NdId) NdIndexByIds[N.Id]=i DpfMesh.AddNode(N.Id, [N.X, N.Y, N.Z]) i+=1 for ElId in ElIds: E=MechMesh.ElementById(ElId) DpfMesh.AddSolidElement(E.Id,[NdIndexByIds[N.Id] for N in E.Nodes]) return DpfMesh def readDataToMap(filename,scale_factor=1.): # Filename: file to read from. Assumes a tab separated file with # node_id X Y Z temperature and a first line to be ignored # Scale factor used to match mechanical mesh unit (m) and file contents unit with open(filename,'r') as f: lines=f.readlines() mapping_nodes=dpf.FieldsFactory.Create3DVectorField(len(lines)-1) mapping_field=dpf.FieldsFactory.CreateScalarField(len(lines)-1) idx=1 for line in lines[1:]: line_sp=line.split('\t') coord=[float(line_sp[i])*scale_factor for i in range(1,4)] value=float(line_sp[4]) mapping_nodes.Add(idx,coord) mapping_field.Add(idx,[value]) idx+=1 return mapping_nodes, mapping_field # Convert Mechanical mesh to DPF mesh mech_dpf.setExtAPI(ExtAPI) dpf_mesh = GetDpfMeshFromMechMesh(ExtAPI) # Get user_files folder proj_dir=ExtAPI.DataModel.Project.ProjectDirectory user_dir=os.path.join(proj_dir,'user_files') # Read data to map # Example file is in mm, so convert from mm to m mapping_file=os.path.join(user_dir,'ExtData_Temp_Valve.txt') source_nodes,source_field=readDataToMap(mapping_file,1e-3) # Define mapping workflow # This will prepare the mapping between the source points and the targets filter_radius=10e-3 op = dpf.operators.mapping.prepare_mapping_workflow() # operator instantiation op.inputs.input_support.Connect(source_nodes) op.inputs.output_support.Connect(dpf_mesh) op.inputs.filter_radius.Connect(filter_radius) mapping_workflow = op.outputs.mapping_workflow.GetData() # Now we can map the data # THe workflow is reused multiple times for various # source fields (here the variation is a scaling of the source field, so mapping is done only once) mapping_workflow.Connect('source',source_field) #Connect field to be mapped mapped_field=mapping_workflow.GetOutputAsField('target') # extract mapped value field_data=mapped_field.Data nids=mapped_field.ScopingIds # Temperatures are scaled based on time step for i in range(len(nids)): cmd='bf,{0},temp,{1}'.format(nids[i],field_data[i]*(1+(solver_data.CurrentStep-1)*.1)) solver_input_file.WriteLine(cmd)
