Possibility to create more than 1 custom results plot per ACT Extension XML file?
NikolasYounker
NikolasYounker Member Posts: 7
Is it possible to create more than 1 custom results plot per ACT extension using xml/ironpython? I feel like it should be possible depending on how the xml is formatted but wanted to get opinions before I spent an extended amount of time on a potential dead end. I've looked to try and find similar questions/results and have been left emptyhanded. Thank you in advance for your answers!
  • Landon Mitchell Kanner
    Yes. You can define multiple custom results in the XML file. Then end users (or ACT scripts) can create multiple instances of each custom result in the tree.
