Create an array of spheres in Spaceclaim
Erik Kostson
edited March 2024 in 3D Design
Do we have an example of creating an array/multiple spheres, based on their location (x,y,z) and radius (this information could be given in a text file say, with 4 columns, corresponding to x,y,z,radius)?
  • Erik Kostson
    edited March 2024
    Below is an example that does that (reads in a text file with the format described above - has 4 columns with x,y,z,radius - see image below on this format).
    import csv
    with open('D:\spherelocradt.txt', 'rb') as f:
        reader = csv.reader(f)
        for row in reader:
            x=(float(row[0]))
            y=(float(row[1]))
            z=(float(row[2]))
            x1=(float(row[0])-float(row[3]))
            SphereBody.Create(Point.Create(MM(float(x)), MM(float(y)), MM(float(z))),
            Point.Create(MM(float(x1)), MM(float(y)), MM(float(z))), ExtrudeType.None)
  • Erik Kostson
    edited March 2024
    If the text file is tab delimited we can replace in the script above all the lines reading the data so upto SphereBody.Create. Also if it is space separated we can replace the "\t" with "\s".
    myt=[]
    f=open('D:\spherelocradtab.txt', 'r')
    for line in f:
        myt=(line.split("\t"))
        x=(float(myt[0]))
        y=(float(myt[1]))
        z=(float(myt[2]))
        x1=(float(myt[0])-float(myt[3]))
