Pydpf commands html
Ansyslearner
Ansyslearner Member Posts: 12
In some of the pdf docs we received the following images:
How can I get this html documentation with code snippets?
Best Answers
    Use this code to generate the DPF doc in .html format from Mechanical:
    import mech_dpf
    my_output_path = (r"D:\Test\Resources")
    op = dpf.operators.utility.html_doc()
    op.inputs.output_path.Connect(my_output_path)
    op.Run()
    Indeed this is another place you can get the documentation. However this link is the one to the PyDPF documentation, so you will only see the CPython example of usage.
  • Ansyslearner
    Thank you for this commands.
  • Ansyslearner
    I see similar code snippets and manual from here:
    https://dpf.docs.pyansys.com/version/stable/operator_reference_load.html
  • Ansyslearner
    edited March 2024
    Hi, I am running the equivalent html documentation in Cpython on linux:
    my_output_path = ('/linux/path/to/my/documentation/')
    op = dpf.operators.utility.html_doc() #operator instantiation
    op.inputs.output_path.connect(my_output_path)
    op.run()
    I receive the following error (resulting from op.run() line):
    ansys.dpf.gate.errors.DPFServerException: html_doc:0<-basic_string::replace: __pos (which is 18446744073709551615) > this->size() (which is 0)
    Something could be incorrect in the path definition. Could you try without providing a path ? The default will be working directory.
  • Ansyslearner
    Run from the following lines:
    op.inputs.output_path.connect() # Tried with and without commenting this line
    op.run()
    Created the following error message:
    File ".../python3.9/site-packages/ansys/dpf/core/dpf_operator.py", line 645, in run
    self.get_output()
    File ".../python3.9/site-packages/ansys/dpf/core/dpf_operator.py", line 488, in get_output
    return self._api.operator_run(self)
    File ".../python3.9/site-packages/ansys/dpf/gate/generated/operator_capi.py", line 696, in operator_run
    raise errors.DPFServerException(sError.value)
    It does create dataProcessingDoc.html with 0 KB.
    This looks like a bug. Could you please report it by creating an issue here? https://github.com/ansys/pydpf-core/issues Thank you
  • Ansyslearner
    edited March 2024
    Noted. Thanks!
