The package 'docker' is required to use the LocalDockerInstance class
Suneel
Suneel Member Posts: 13
edited March 2024 in 3D Design
I am trying to reproduce the results as provided in PyAnsys Geometry 101: Plotter.
https://geometry.docs.pyansys.com/version/stable/examples/01_getting_started/05_plotter_picker.html
When I execute the second set of codes (Load modeling service), I am getting following error.
I already have Ansys CAD product installed. I am using Ansys 2024 R1, contains spaceClaim.
The version of PyAnsys Geometry is 0.4.11
  • RobPasMue
    RobPasMue Member, Employee, GitHub-issue-creator Posts: 12
    Second Anniversary 10 Comments First Answer Name Dropper
    Hi @Suneel!
    As stated in the description of the second block:
    Load the modeling service. While the following code uses a Docker image to interact with the modeling service, you can use any suitable method mentioned in the preceding examples.
    That specific code snippet is using a Docker image to run the example. In your case, you could substitute it with the following:
    modeler = launch_modeler("spaceclaim")
