How can I make the average transmission loss a parameter?
Erik Kostson
How can I make the average transmission loss a parameter in a harmonic acoustic analysis?
  • Erik Kostson
    edited March 2024 Answer ✓
    The average is not available to be made parameter, only min and max is. It is still possible to do this though.
    Below is one way of doing that (using python code). It assumes that we have a harmonic acoustic analysis with a results object called Transmission Loss. Due to a limitation in reading in these results, it needs to save the result to file, read the content of the file, and calculate what is needed (average in this case), and make that value a parameter.
    Script:
        Called after post processing.
        Keyword Arguments :
            solution -- Solution
        import csv
        myfile='D:\mtl.txt'
        ExtAPI.Log.WriteMessage('Start')
        tl = DataModel.GetObjectsByName("Transmission Loss")[0]
        tl.Activate()
        tl.ExportToTextFile(myfile)
        avtl=0
        tot=0
        nr=0
        with open(myfile, 'rb') as f:
            data = csv.reader(f,delimiter='\t')
            next(data)
            for row in data:
                nr=nr+1
                tot=tot+(float(row[1]))
        avtl=tot/nr
        #ExtAPI.Log.WriteMessage(str(avtl))
        this.GetCustomPropertyByPath("My Results/mytl").Value=avtl
    Property provide:
    def reload_props():
        this.PropertyProvider = None
        # comment the following return to allow the rest of the function definition to be executed and add properties
        #return
        Some sample code is provided below that shows how to:
            1. Create an instance of the Provider. The Provider class is used to add custom properties to the details.
            2. Use the Provider instance to add custom properties.
            3. Configure those custom properties.
        provider = Provider()
        group = provider.AddGroup("My Results")
        double_prop = group.AddProperty("mytl", Control.Double)
        #expression_prop = group.AddProperty("Expression Property 1", Control.Expression) # Expression is a string
        # Configure the double property to be parameterizable. As a default the property will be an input parameter.
        # However, by updating the ParameterType property, it can be configured to be a output parameter as well.
        double_prop.CanParameterize = True
        double_prop.ParameterType = ParameterType.Output
    # region Property Provider Template
    from Ansys.ACT.Mechanical.AdditionalProperties import PropertyProviderAdapter
    from Ansys.ACT.Mechanical.AdditionalProperties import *
    The property_templates module is located in %awp_root212%\aisol\DesignSpace\DSPages\Python\mech_templates
    from mech_templates import property_templates
    property_templates.set_ext_api(ExtAPI)
