How to plot temperature time history on a set of nodes in Mechanical using DPF?
Rohith Patchigolla
Member, Moderator, Employee Posts: 253
I have some nodes on which I want to plot temperature variation over time in a thermal analysis. I have not created a named selection for these nodes. How can I use Python Result object to plot time vs Temperature plot for these nodes?
Tested in 23R2 and 24R1.
Step 1: RMB on Solution (of a thermal analysis) --> Insert --> Python Results
Step 2: You can use the below script in a Python Result object in Mechanical to plot temperature time history on a set of nodes provided as an input via a list "nodeIds".def post_started(sender, analysis):# Do not edit this line define_dpf_workflow(analysis) # Uncomment this function to enable retrieving results from the table/chart def table_retrieve_result(value):# Do not edit this line import mech_dpf import Ans.DataProcessing as dpf wf = dpf.Workflow(this.WorkflowId) wf.Connect('contour_selector', value) this.Evaluate() def define_dpf_workflow(analysis): import mech_dpf import Ans.DataProcessing as dpf mech_dpf.setExtAPI(ExtAPI) dataSource = dpf.DataSources(analysis.ResultFileName) model = dpf.Model(dataSource) #Input node numbers nodeIds = [10265, 10266] scoping = dpf.Scoping() scoping.Location = 'Nodal' scoping.Ids = nodeIds temp = dpf.operators.result.temperature() time_freq_support = dpf.operators.metadata.time_freq_provider() time_freq_support.inputs.data_sources.Connect(dataSource) n_sets = time_freq_support.outputs.time_freq_support.GetData().NumberSets timeScop = dpf.Scoping() # Compute time history time_steps = range(1, n_sets + 1) timeScop.Ids = time_steps temp.inputs.time_scoping.Connect(timeScop) temp.inputs.data_sources.Connect(dataSource) temp.inputs.mesh_scoping.Connect(scoping) dpf_workflow = dpf.Workflow() dpf_workflow.Add(temp) dpf_workflow.SetInputName(temp, 0, 'time') dpf_workflow.Connect('time', timeScop) dpf_workflow.SetOutputContour(temp) dpf_workflow.Record('wf_id', False) this.WorkflowId = dpf_workflow.GetRecordedId()
Step 3: RMB on Solution --> Evaluate all results
