How to print time, load step and substep information in Mechanical via DPF?
Rohith Patchigolla
Member, Moderator, Employee Posts: 242
I want to extract time, load step and substep information in Mechanical via DPF, so that I can connect load step and substep number to Time value in DPF.
The below code should print Result Set Num, Time Value, Load Step, Substep corresponding to result file of a selected Analysis in Mechanical.
import mech_dpf import Ans.DataProcessing as dpf baseAnalysis = DataModel.AnalysisList[0] baseDataSource = dpf.DataSources(baseAnalysis.Solution.ResultFilePath) timeFreqDataTemp = dpf.operators.metadata.time_freq_provider(data_sources=baseDataSource).outputs.time_freq_support.GetData() timeFreqDataLines = str(timeFreqDataTemp).split('\n') timeFreqDataLines = [line.strip() for line in timeFreqDataLines if line.strip()][3:] timeFreqDataFloat = [list(map(float, line.split())) for line in timeFreqDataLines]
