Following script can be modified based on the given .unv file. User need to set correctly the starting line number for node location and stress results.
import csv
from collections import OrderedDict
#User Inputs
locStart = 14 #Line where the Node location starting
stressStart = 37277 #Line where the Stress results starting
filepath_csv = "C:\\ExtData.csv"
filepath_unv = "C:\\Simufact.unv"
with open(filepath_unv, 'r') as unvfile:
allLines = unvfile.readlines()
nodeLoc = OrderedDict()
count = 0
check = True
while check:
index = locStart+count-1
nID = allLines[index].strip().split()[0]
if nID !="-1":
nLoc = allLines[index+1].strip().split()
nodeLoc[nID] = nLoc
count +=2
elif nID =="-1":
check = False
stressComp = OrderedDict()
count = 0
check = True
while check:
index = stressStart+count-1
if nID !="-1":
sComp = allLines[index+1].strip().split()
stressComp[nID] = sComp
count +=2
elif nID =="-1":
check = False
combinedDict = OrderedDict()
for key in nodeLoc.keys():
combinedDict[key] = nodeLoc[key]+stressComp[key]
with open(filepath_csv, 'wb') as csvfile:
csvfile.write('NodeID'+','+'X'+','+'Y'+','+'Z'+','+'SX'+','+'SY'+','+'SZ'+','+'SXY'+','+'SYZ'+','+'SXZ')
csvfile.write('\n')
writer = csv.writer(csvfile)
for key,value in combinedDict.items():
writer.writerow([key,value[0],value[1],value[2],value[3],value[4],value[5],value[6],value[7],value[8]])
csvfile.close()
