Written for Ansys v23r1
Check that in Workbench - Tools - Options - Mechanical - Connect/Run Python Code Objects When Mechanical is Launched is checked (on).
Then in Mechanical - File - Options - Export - Text File Export - make sure Enclude Node Numbers is set to Yes **and **Include Node Location is set to yes.
Then in your Mechanical instance insert a Python Code Object in the Solution branch (Right click - Insert - Python Code Object) and set the Target Callback to After Post (after the results have been generated).
! Make sure to change the path to a directory (save_directory = ) where you want to save results. Or you can use the wbjn module to find the project directory.
! set the named selection to a **nodal **named selection in your model.
Called after post processing.
Keyword Arguments :
solution -- Solution
import os, wbjn
dp=wbjn.ExecuteCommand(ExtAPI,"returnValue(Parameters.GetCurrentDesignPoint().DisplayText)")
named_selection_name = 'mirror1'
result_name = 'Total Deformation' + '_' + named_selection_name
save_directory = r'D:\\temp\b'
node_file_name = named_selection_name + '_nodes.txt'
result_save_name = dp + '_' + result_name + '.txt'
named_selection = ExtAPI.DataModel.GetObjectsByName(named_selection_name)[0]
named_selection.ExportToTextFile(os.path.join(save_directory,node_file_name))
results = ExtAPI.DataModel.GetObjectsByType(DataModelObjectCategory.Result)
result_names = [i.Name for i in results]
if result_name not in result_names:
result = ExtAPI.DataModel.Project.Model.Analyses[0].Solution.AddTotalDeformation()
scope = ExtAPI.DataModel.GetObjectsByName(named_selection_name)[0]
result.Name = result_name
result.Location = scope
# set time etc for your specific result here
result.EvaluateAllResults()
result = ExtAPI.DataModel.GetObjectsByName(result_name)[0]
result.ExportToTextFile(os.path.join(save_directory,result_save_name))
pass
