How can I extract mesh data from a selected face / body?
Nikos Kallitsis
I have selected a face / body and know the ID of the item. How can I retrieve some mesh information like elements and nodes?
  • Nikos Kallitsis
    This can be achieved with some Python commands executed in the Mechanical Scripting interface.
    First let's check how you can get the face / body Id. Assuming you've created a Named Selection scoped to the face(s) / body(ies), you can select that object and check the Ids of the scoped parts:
    sel = DataModel.GetObjectsByName('NamedSelection')[0]
    selectionIds = sel.Ids
    To get the element / node data, the mesh associated with the selected face / body must first be selected. In the case of a face with Id = 7 for example:
    myFaceId = 7
    meshData = ExtAPI.DataModel.Project.Model.Analyses[0].MeshData
    meshFace = meshData.MeshRegionById(myFaceId)
    Then the element / node data can be retrieved from the meshFace object:
    elementIdsMeshFace = meshFace.ElementIds
    elementIds = meshFace.ElementIds
    nodeIds = meshFace.NodeIds
    To access the element / node objects themselves:
    elements = meshFace.Elements
    nodes = meshFace.Nodes
    To retrieve the X, Y, Z, coordinates of a selected node:
    xLoc = nodes[0].X
    yLoc = nodes[0].Y
    zLoc = nodes[0].Z
    In the case of bodies, the commands are exactly the same.
    To export the desired data to a text file, you can do so by using the usual Python commands with the 'os' library after importing it.
