How can I export temperature result data in Mechanical to a csv file using a Python code object?
arranosr71
Member Posts: 4
Hello everyone, it is my first post in this forum.
I have a thermal model in ANSYS Mechanical with a couple of interesting temperature result objects on it. The thing is I'd like to create a Python code object that automatically exports these results every time the simulation is completed (the same way as doing a right-clik ->Export Text File on the interface).
Is there any way of doing that?
Thank you all for your attention
Hello, you could investigate using something in this direction:
import os analysis=ExtAPI.DataModel.Project.Model.Analyses[0] lotationToExport = analysis.WorkingDir fileName = "exported.txt" fileToExport = os.path.join(lotationToExport,fileName) #Use your results name here resultsName = "myResultName" r1=ExtAPI.DataModel.GetObjectsByName(resultsName)[0] r1.ExportToTextFile(fileToExport)
