Calculate center of mass using PyDPF
Ayush Kumar
Member, Moderator, Employee Posts: 494
from ansys.dpf import core as dpf rst = r"\Path\to\file.rst" ds = dpf.DataSources(rst) model = dpf.Model(rst) dpf_mesh = model.metadata.meshed_region all_mats = [] mats = dpf_mesh.property_field("mat") mat_prop = model.operator("mapdl_material_properties") mat_prop.inputs.materials.connect(mats) mat_prop.inputs.properties_name.connect("DENS") mat_field = mat_prop.outputs.properties_value.get_data()[0] for eid in dpf_mesh.elements.scoping.ids: mat_id = mats.get_entity_data_by_id(eid) density = mat_field.get_entity_data_by_id(mat_id[0]) all_mats.append(density) # Create Density Field density = dpf.fields_factory.create_scalar_field(num_entities=dpf_mesh.elements.n_elements) density.location = dpf.locations.elemental density.scoping.ids = dpf_mesh.elements.scoping.ids density.data = all_mats # Element volume el_vol = dpf.operators.geo.elements_volume(mesh=dpf_mesh) # Calculate elemental mass elemental_mass = dpf.operators.math.generalized_inner_product(fieldA=el_vol, fieldB=density) # Get element centroids centroids = dpf.operators.result.element_centroids(data_sources=ds) centroids_f = centroids.outputs.fields_container.get_data()[0] # Get common scoping eids = dpf.operators.scoping.intersect() # operator instantiation eids.inputs.scopingA.connect(centroids_f.scoping) eids.inputs.scopingB.connect(density.scoping) eids_out = eids.outputs.intersection.get_data() # Rescoped to ensure same elements centroids_r = dpf.operators.scoping.rescope(fields=centroids_f, mesh_scoping=eids_out) density_r = dpf.operators.scoping.rescope(fields=density, mesh_scoping=eids_out) # Density * centroids den_dot_cent = dpf.operators.math.generalized_inner_product(fieldA=centroids_r.outputs.fields_as_field, fieldB=density_r.outputs.fields_as_field) # Integrate coordinates over element volume den_dot_cent_int = dpf.operators.geo.integrate_over_elements(field=den_dot_cent, mesh=dpf_mesh) # Int. across body all_sum = dpf.operators.math.accumulate(fieldA=den_dot_cent_int) all_sum_f = all_sum.outputs.field.get_data() all_sum_f.unit = "" # Unit causing issues in division # Total mass total_mass = dpf.operators.math.accumulate(fieldA=elemental_mass) total_mass_f = total_mass.outputs.field.get_data() total_mass_f.unit = "" # COG cog = dpf.operators.math.component_wise_divide(fieldA=all_sum_f, fieldB=total_mass_f)
