By PyAEDT, I want to determine more than two faces using the bottom_face_y function.
Taeseok
Taeseok Member Posts: 2 **
If there are multiple faces for an object and I want to determine all the faces located at the bottom (-y) in order to set the source, how can I do that using the bottom_face_y function?
  • Chris Harrold
    admin
    @svandenb-dev - can you take a look at this one for assistance? Thanks!
  • svandenb-dev
    svandenb-dev Member, Employee Posts: 10
    10 Comments Second Anniversary Ansys Employee First Answer
  • Giulia M.
    Giulia M. Member, Employee Posts: 19
    Second Anniversary 10 Comments 5 Answers Ansys Employee
    edited May 2024
    Hi @Taeseok,
    Thanks for your message.
    If you try to use bottom_face this will give you back only one of the faces.
    What you could do is to compare normal of the faces of your object.
    Suppose my object is a box:
    my_box = m3d.modeler["my_box"]
    you can get the faces with the same normal as:
    faces = [face for face in box.faces if face.normal == [0, 0, -1]]
    Hope this helps!
    Kind regards,
    Giulia
