How to use DPF in WB Project Page Scripting Console?
Ayush Kumar
Ayush Kumar Member, Moderator, Employee Posts: 495
edited April 2024 in Structures
  • Ayush Kumar
    edited April 2024
    You need to import all the relevant libraries for DPF. Below is an example code (tested with 2024R1)
    import clr
    import sys
    import Ansys
    def DPFAddReference(reference_name):
        try:
            clr.AddReference(reference_name);
            return
        except:
            print(reference_name + " reflection was not generated.")
    def importPlugins():
        DPFAddReference("Ans.Utilities")
        DPFAddReference("CS_DataProcessing")
        from Ans.DataProcessing import DataProcessingCore
        from Ans.DataProcessing.load import GeneratePluginDll
        DataProcessingCore.Initialization()
        DPFAddReference("Ans_Dpf_Native_dll_cs")
        DPFAddReference("Ans_Dpf_FEMutils_dll_cs")
        DPFAddReference("meshOperatorsCore_dll_cs")
        DPFAddReference("mapdlOperatorsCore_dll_cs")
        DPFAddReference("Ans_Dpf_Math_dll_cs")
        DPFAddReference("Ans_Dpf_Hdf5_dll_cs")
        DPFAddReference("Ans_Dpf_PointCloudSearch_dll_cs")
        DPFAddReference("Ans_Dpf_Mechanical_dll_cs")
        DPFAddReference("Ans_Dpf_MechanicalResults_dll_cs")
    importPlugins()
    rst_path = r"\Path\to\file.rst"
    model = dpf.Model(rst_path)
    print(model.ResultInfo.AnalysisType)
