PyGeometry is failing if I increase number of loops to create a geometry
Hi All,
I am doing an excersise to understand how much time required to create an geometry and I am comparing between standalone Sc and PyGeometry. For this excersise I have taken a simple plate with a hole geometry. The code works somthing like below
where 50 indicates number of loops.
Following is the code
st = time.time()
modeler = launch_modeler(mode="spaceclaim")
outer_hole_radius = Distance(0.5, UNITS.m)
j = 0
k = 0
design = modeler.create_design("ExtrudedPlate")
for i in range (50):
originX = j
oroginY = k
point1X = originX-4 point1Y = oroginY+5 point2X = originX+4 point3Y = oroginY-5 center1X = originX+3 center1Y = oroginY+4 center2X = originX-3 center2Y = oroginY-4 sketch = Sketch() ( sketch.segment(start=Point2D([point1X, point1Y], unit=UNITS.m), end=Point2D([point2X, point1Y], unit=UNITS.m)) .segment_to_point(end=Point2D([point2X, point3Y], unit=UNITS.m)) .segment_to_point(end=Point2D([point1X, point3Y], unit=UNITS.m)) .segment_to_point(end=Point2D([point1X, point1Y], unit=UNITS.m)) .box( center=Point2D([originX, oroginY], unit=UNITS.m), width=Distance(3, UNITS.m), height=Distance(3, UNITS.m), ) .circle(center=Point2D([center1X, center1Y], unit=UNITS.m), radius=outer_hole_radius) .circle(center=Point2D([center2X, center2Y], unit=UNITS.m), radius=outer_hole_radius) .circle(center=Point2D([center2X, center1Y], unit=UNITS.m), radius=outer_hole_radius) .circle(center=Point2D([center1X, center2Y], unit=UNITS.m), radius=outer_hole_radius) ) body = design.extrude_sketch(f"PlateLayer"+str(i), sketch, Quantity(2, UNITS.m)) board_named_selection = design.create_named_selection("Plate"+str(i), bodies=[body]) j = j+8 k = k+10
et = time.time()
elapsed_time = et - st
print('Execution time:', elapsed_time, 'seconds')
The code is working fine for up-to range = 50 if I increase the range values greater than 50 the code is failing, following is the error
Any idea why it is failing
Hi @Suneel
As this might be an issue, post it here:
https://github.com/ansys/pyansys-geometry/issues
All the best
Erik
Hi Erik,
I have posted it in the github (https://github.com/ansys/pyansys-geometry/issues).
Dose it mean at present no solution present.Suneel
