This examples shows how the level_set parameter can be extracted from d3plot in pydpf. The level_set parameter has a positive value where the fluid phase exists and negative everywhere else. In this example, the level_set is cast as a parameter with either 0 or 1 and an iso surface of the value is extracted. This gives us just the resin domain. The minimum y coordinate of this domain is the boundary of the wave front. By tracking this coordinate, the displacement and in turn the velocity of the resin flow can be computed.
from ansys.dpf.core import operators as ops
import numpy as np
#### Load d3plot as 'ms' data
dpf.load_library(r'D:\PYDYNA_PUBLIC_RELEASE_0.4\Ans.Dpf.LSDYNAHGP_2024_4_18\Ans.Dpf.LSDYNAHGP.dll', 'lsdyna')
ds = dpf.DataSources()
ds.set_result_file_path(r'C:\Users\sadya\Downloads\2Adya\d3plot')
model = dpf.Model(ds)
print(model)
#### Extract the number of states in d3plot
tf = model.metadata.time_freq_support.time_frequencies.data
level_set = model.results.level_set.on_all_time_freqs().eval()
print(level_set)
#### Loop through the states to get the level_set results
distance = [0]
velocity = []
count =1
for i in range(len(tf)-1):
level_set[i].data = np.where(level_set[i].data > 0,1,0
#### Extract iso surface with current level_set as the field
op = dpf.operators.mesh.iso_surfaces(
field=level_set[i],
num_surfaces=1,
mesh=model.metadata.meshed_region,
#### get the mesh from the operator
result = op.outputs.meshes().get_mesh(0).grid
#### compute distance and velocity
distance.append(np.min(result.points[:,1]))
if count > 1:
velocity.append((distance[count]-distance[count-1])/(tf[count]-tf[count-1]))
count+=1
plt.plot(tf[2:],velocity)
plt.xlabel('Time')
plt.ylabel('Velocity of resin front')
plt.show()
level_set.animate(show_edges=False,clim = [-0.5,1],opacity="linear")
