script to automatically export coordinate systems in DesignModeler
RK
RK Member, Employee Posts: 11
Hello all,
There are over 100 local coordinate systems, but I don't want to manually export them out. Is there any script that could write all the coordinate systems (each has one center and 3 axes) into a file? Thanks!
Regards,
Rahul
  • M
    M Member, Employee Posts: 256
    edited May 2024
    posted the mechanical solution before realizing it was dm.
    edited May 2024
    You can set the property of the CS to be exported and then either take the .agdb file into mechanical or SC/Disco. This is a script to export the CS info once in SC/Disco. The DM scripting is not very full as of 24.1 releases, so it will be hard to export this and likely the API will not be supported if you find a way.
    import csv
    Root = GetRootPart()
    FilePath=r'C:\Users\mthompso\MyData\DeleteThis\CsData.csv'
    DirNames = ["X","Y","Z"]
    AxisNames = [[AA+ " Axis: "+A for A in DirNames] for AA in DirNames]
    Header = ["Name"]+AxisNames[0]+AxisNames[1]+AxisNames[2]+["Origin: "+A for A in DirNames]
    with open(FilePath, "wb") as csv_file:
    writer = csv.writer(csv_file, delimiter=',')
    writer.writerow(Header)
    for CS in Root.CoordinateSystems:
    AxisX = list(CS.Frame.AxisX.Direction)
    AxisY = list(CS.Frame.AxisY.Direction)
    AxisZ = list(CS.Frame.AxisZ.Direction)
    Orig = list(CS.Frame.Origin)
    Data = [CS.GetName()]+Orig+AxisX+AxisY+AxisZ
    writer.writerow(Data)
  • RK
    Thank you, Mike!
