Unable to get nodout results from LS DYNA binout file using pyDPF
Jithin
Member Posts: 1 **
I'm trying to read the binout file from an LS DYNA explicit simulation. I tried following the example given in https://dpf.docs.pyansys.com/version/stable/examples/01-transient_analyses/02-lsdyna_operators.html#binout-file-results-extraction
After reading the binout file, I'm only able to see results from the glstat branch of the binout file. nodout results are not listed at all when I check model.results.
Is there something else I need to do to access nodout results?
@Ramdane - I do not know if this is DPF or Dyna, but figured I would start with you? Any thoughts?
