Hi All,
With the help of the script I have created a bunch of Named selection (see image below) and each named selection contains two surfaces (source and target). I am looping through each group and pulling source face up-to target face based on the gap between tem.
The problem I am facing is, for some reason if pull operation fails the entire Spaceclaim getting struck. How can we skip that group if it is failing and continue with the next.
Regards,
Suneel
