How can we create a vertex on a face belong to a cylinder?
Say we have a cylindrical body, how can we then create a vertex on each of the 2 capping/end faces (so at the top and bottom)?
Best Answers
Below is one of many possible ways of doing this (works with API.V23.2)- the reference test example below, assumes there is at least one cylindrical body with 2 planar capping/end faces and one cylindrical face.
assembly = GetRootPart() bodies=assembly.Bodies mybodies=[] cx=[] cy=[] cz=[] for body in bodies: faces=body.Faces nrfaces=len(faces) if body.GetMaster().Shape.IsClosed==True and nrfaces==3: # check it is a solid body and cylindrical consist of 3 faces mybodies.append(body) for face in faces: # splits face in half if str(face.Shape.Geometry.GetType())=="SpaceClaim.Api.V232.Geometry.Plane": edges=face.Edges a=MeasureHelper.GetCentroid(Selection.Create(face)) # gets centroid (can be used to get vertex) cx.append(a[0]) cy.append(a[1]) cz.append(a[2]) for edge in edges: options = SplitFaceOptions() fselection = FaceSelection.Create(face) point = EdgeSelection.Create(edge).Items[0].EvalProportion(0.5).Point result = SplitFace.ByParametric(fselection, point, FaceSplitType.Perpendicular, options) f=(body.Faces[nrfaces]) nwedges=f.Edges nredges=len(nwedges) for nedge in nwedges: # splits new line edge in half -> vertex is created if str(nedge.Shape.Geometry.GetType())=="SpaceClaim.Api.V232.Geometry.Line": # gets the staigt edge on the half circular face selections = EdgeSelection.Create(nedge) end=nedge.Shape.EndPoint result = SplitEdge.ByCount(selections,2)
The above can be adapted to loop through a named selection containing planar faces (e.g., capping plane/face of a cylinder). These faces will be split in half and a vertex will be finally created at the centroid of the face. The centroid values of the face are also stored (cx,cy,cz) in case they would need to be used.
groups = GetActiveWindow().ActiveWindow.Groups cx=[] cy=[] cz=[] for ns in groups: me=ns.Members for mem in me: if str(mem.Shape.Geometry.GetType())=="SpaceClaim.Api.V232.Geometry.Plane": ## can be changed say to "SpaceClaim.Api.V232.Geometry.Cone" edge=mem.Edges[0] a=MeasureHelper.GetCentroid(Selection.Create(mem)) cx.append(a[0]) cy.append(a[1]) cz.append(a[2]) options = SplitFaceOptions() fselection = FaceSelection.Create(mem) point = EdgeSelection.Create(edge).Items[0].EvalProportion(0.5).Point result = SplitFace.ByParametric(fselection, point, FaceSplitType.Perpendicular, options) nme=ns.Members for i in range(0,len(nme),2): nwedges=nme[i].Edges for nedge in nwedges: if str(nedge.Shape.Geometry.GetType())=="SpaceClaim.Api.V232.Geometry.Line": selections = EdgeSelection.Create(nedge) end=nedge.Shape.EndPoint result = SplitEdge.ByCount(selections,2)
In addition to the above code, we can add this to create groups from the vertices generated at the centre of the face (so add the below code to the above script):
import math myv=[] myvIds=[] dist=1E12 nme=ns.Members # create named selection for j in range(0,len(cx)): for i in range(0,len(nme),2): nwedges=nme[i].Edges for nedge in nwedges: if str(nedge.Shape.Geometry.GetType())=="SpaceClaim.Api.V232.Geometry.Line": ep=nedge.GetChildren[CurvePoint]() for e in ep: ex=e.Position[0] ey=e.Position[1] ez=e.Position[2] dists=math.sqrt((float(cx[j])-ex)**2+(float(cy[j])-ey)**2+(float(cz[j])-ez)**2) if dists<dist: myvs=(e) dist=dists primarySelection = Selection.Create(myvs) secondarySelection = Selection.Empty() result = NamedSelection.Create(primarySelection, secondarySelection) dist=1E12 myv.append(myvs)
Finally the below script adds all the 3 scripts above together. In summary it gets the first named selection/group containing planar faces (e.g., capping plane/face of a cylinder). These faces will be split in half and a vertex will be finally created at the centroid of the face. The centroid values of the face are also stored (cx,cy,cz) as they are used in the end to get the vertex closest to them (generating one group for each vertex).
import math group = GetActiveWindow().ActiveWindow.Groups[0] cx=[] cy=[] cz=[] myv=[] myvIds=[] dist=1E12 me=group.Members for mem in me: if str(mem.Shape.Geometry.GetType())=="SpaceClaim.Api.V232.Geometry.Plane": ## can be changed say to "SpaceClaim.Api.V232.Geometry.Cone" edge=mem.Edges[0] a=MeasureHelper.GetCentroid(Selection.Create(mem)) cx.append(a[0]) cy.append(a[1]) cz.append(a[2]) options = SplitFaceOptions() fselection = FaceSelection.Create(mem) point = EdgeSelection.Create(edge).Items[0].EvalProportion(0.5).Point result = SplitFace.ByParametric(fselection, point, FaceSplitType.Perpendicular, options) group = GetActiveWindow().ActiveWindow.Groups[0] nme=group.Members # generate centre vertex / split line in half for i in range(0,len(nme),2): nwedges=nme[i].Edges for nedge in nwedges: if str(nedge.Shape.Geometry.GetType())=='SpaceClaim.Api.V232.Geometry.Line': selections = EdgeSelection.Create(nedge) end=nedge.Shape.EndPoint result = SplitEdge.ByCount(selections,2) group = GetActiveWindow().ActiveWindow.Groups[0] nmes=group.Members # generate group of centre vertex for j in range(0,len(cx)): for i in range(0,len(nmes),2): nwedges=nmes[i].Edges for nedge in nwedges: if str(nedge.Shape.Geometry.GetType())=="SpaceClaim.Api.V232.Geometry.Line": ep=nedge.GetChildren[CurvePoint]() for e in ep: ex=e.Position[0] ey=e.Position[1] ez=e.Position[2] dists=math.sqrt((float(cx[j])-ex)**2+(float(cy[j])-ey)**2+(float(cz[j])-ez)**2) if dists<dist: myvs=(e) dist=dists primarySelection = Selection.Create(myvs) secondarySelection = Selection.Empty() result = NamedSelection.Create(primarySelection, secondarySelection) dist=1E12 myv.append(myvs)
1
