How can I create a selection of all edges parallel to the x-axis using Scripting?
Ryoma
Member, Employee Posts: 7
How can I create a selection of all edges parallel to the x-axis using Scripting ?
You can do that by using scripts below.
This code traverses all edges in the model and select the edge parallel to the x-axis.geometry = ExtAPI.DataModel.GeoData assemblies = geometry.Assemblies assemblies_count = assemblies.Count #selection info selmgr=ExtAPI.SelectionManager selmgr.ClearSelection() selection_info = selmgr.CreateSelectionInfo(SelectionTypeEnum.GeometryEntities) target_direction = [1, 0, 0] #Parallel to X-Axis neg_target_direction =[ -1*i for i in target_direction] # Select Edges parallel to Z-Axis with Transaction(): for assembly in assemblies: assembly_name = assembly.Name parts = assembly.Parts parts_count = parts.Count for part in parts: part_name = part.Name bodies = part.Bodies bodies_count = bodies.Count for body in bodies: faces = body.Faces faces_count = faces.Count for face in faces: edges = face.Edges edges_count = edges.Count for edge in edges: direction = list(edge.TangentAtParam(0)) if direction== target_direction: selection_info.Ids.Add(edge.Id) elif direction== neg_target_direction: selection_info.Ids.Add(edge.Id) selmgr.NewSelection(selection_info)
