PyDPF does not return displacement at all the nodes when used mapping operator
I have a modal analysis result and I need to map the displacement for a particular mode onto a particular path. The path has been created in Mechanical and extracted the points along the path using 'Export Text File option'. To map the displacement along the path I am using the following code:
disp = model.results.displacement.on_all_time_freqs.eval()
points = Points(path_cord) # path_cord: point coordinates along the path (size = (202,3))
mapping_operator = ops.mapping.on_coordinates(
fields_container=disp,
coordinates=field_from_array(points.coordinates.data),
create_support=True,
disp_path = mapping_operator.outputs.fields_container()
disp_path[0].data # contain disp at only 154 points
The problem I am facing here is that the number of points I requested is 202, but the mapping operator returns only 154 points.
Please help me resolve this issue.
Thanks,
Samukham
Could anyone please help me to resolve this issue
