Is there a faster and more efficient way to extract tabular data on Linux?
Collins
Member Posts: 24
Unfortunately
pane=ExtAPI.UserInterface.GetPane(MechanicalPanelEnum.TabularData) control = pane.ControlUnknown
This approach doesn't work on Linux and also the alternative found here:
https://discuss.ansys.com/discussion/comment/4362#Comment_4362
Is very slow.
Thank you
Following up on this question; In case anyone is going through this problem.
I have used the core idea of the referenced algorithm and adapted it for transient analysis (for directional acceleration data).
This runs faster compared to the referenced one because the Python looping is a little more efficientobs = [] DirectionalAcceleration = [child for child in transient_analysis.Solution.Children if child.DataModelObjectCategory == DataModelObjectCategory.DirectionalAcceleration] with Transaction(): time_steps = transient_analysis.GetResultsData().ListTimeFreq for result in DirectionalAcceleration: result_type = result.GetType().ToString() if 'Results' in result_type: result.By = SetDriverStyle.Time t_unit = result.Time.Unit result.DisplayTime = Quantity(time_steps[0], t_unit) result.EvaluateAllResults() data = [result.Average for time in time_steps] obs.append( data)
Note this works fine on Linux.
If anyone finds something faster kindly post here.
CHeer!!
