Add Circular cross section in mechanical via scripting
cedev
cedev Member Posts: 5
I am trying to add a circular cross section in mechanical via the scripting interface.
I can add one using either commands if there is already the "Cross Sections" folder:
cs = Model.CrossSections.AddCircularCrossSection()
cs = ExtAPI.DataModel.Project.Model.CrossSections.AddCircularCrossSection()
If I try to run it when the CrossSections folder doesn't exist I have the following error message:
'NoneType' object has no attribute 'AddCircularCrossSection'
What am I missing?
Best Answers
  • Landon Mitchell Kanner
    edited May 2024 Answer ✓
    Looks like the API is missing coverage for this. I will work with our developers to get it fixed. As a workaround, you can use InternalObject, but please note it is undocumented and unsupported:
    ExtAPI.DataModel.Project.Model.InternalObject.AddCrossSectionGroup()
    Tree.Refresh()
    @mohamed-koubaa, FYI. Will reach out to discuss.
  • Rajesh Meena
    This will be exposed in 2025R1.
