Below is an example using mechdpf for creation of custom field on a custom mesh
Methodology
Mesh Creation
Field Creation
Fields Container Creation
Sample Python Result Code Below:
def define_dpf_workflow(analysis): import mech_dpf import Ans.DataProcessing as dpf #Create mesh mesh = dpf.MeshedRegion(4, 1) mesh.AddNode(1, [ 0.0, 0.0, 0.0 ]) mesh.AddNode(2, [ 10.0, 0.0, 0.0 ]) mesh.AddNode(3, [ 10.0, 10.0, 0.0 ]) mesh.AddNode(4, [ 0.0, 10.0, 0.0 ]) mesh.AddShellElement(1, [ 0, 1, 2, 3 ]) # Set the mesh unit mesh.Unit = "mm" time1_field = dpf.FieldsFactory.Create3DVectorField(4) time2_field = dpf.FieldsFactory.Create3DVectorField(4) time3_field = dpf.FieldsFactory.Create3DVectorField(4) time1_field.Unit = "mm" time2_field.Unit = "mm" time3_field.Unit = "mm" time1_field.ScopingIds = mesh.NodeIds time2_field.ScopingIds = mesh.NodeIds time3_field.ScopingIds = mesh.NodeIds time1_field_data = [0.0,1.0,2.0,3.0,4.0,5.0,6.0,7.0,8.0,9.0,10.0,11.0] time2_field_data = [x*2 for x in [0.0,1.0,2.0,3.0,4.0,5.0,6.0,7.0,8.0,9.0,10.0,11.0]] time3_field_data = [x*3 for x in [0.0,1.0,2.0,3.0,4.0,5.0,6.0,7.0,8.0,9.0,10.0,11.0]] time1_field.Data = time1_field_data time2_field.Data = time2_field_data time3_field.Data = time3_field_data fc = dpf.FieldsContainerFactory.OverTimeFreqFieldsContainer( {0.1: time1_field, 0.2: time2_field, 0.3: time3_field}, "s" ) nrm = dpf.operators.math.norm_fc(fields_container = fc) dpf_workflow = dpf.Workflow() #dpf_workflow.Add(fc) dpf_workflow.Add(nrm) # dpf_workflow.SetInputName(u, 0, 'time') # dpf_workflow.Connect('time', timeScop) dpf_workflow.SetOutputMesh(mesh) dpf_workflow.SetOutputContour(nrm) dpf_workflow.Record('wf_id', False) this.WorkflowId = dpf_workflow.GetRecordedId()
References:
Help Manual Link for Python result
A PyDPF example
