How to extract Joint Forces in Mechanical using DPF.?
Naveen Kumar Begari
Naveen Kumar Begari Member Posts: 91
edited May 2024 in Structures
I want to get joint force reactions using dpf.
  • Naveen Kumar Begari
    edited May 2024
  • Ayush Kumar
    @Naveen Kumar Begari joint forces can be extracted as SMISC forces. You need to scope the joint element id. Below is an example code for for the IronPython API.
    import mech_dpf
    mech_dpf.setExtAPI(ExtAPI)
    #Get data source
    dataSource = mech_dpf.GetDataSources(1)
    my_model = dpf.Model(dataSource)
    my_elemental_scoping = dpf.MeshScopingFactory.ElementalScoping([2431])
    joint_force_x = dpf.Operator("mapdl::smisc")
    joint_force_x.Connect(4,dataSource)
    joint_force_x.Connect(1,my_elemental_scoping)
    joint_force_x.Connect(10,1)
    jf_x_fields = joint_force_x.GetOutputAsFieldsContainer(0)
    jf_x_field = jf_x_fields[0]
    edited May 2024
    Thanks @Ayush Kumar
    edited May 2024
    @Ayush Kumar
    Here, Forces along X directions are getting in 'Newtons-(N)' , where as Forces along y and z directions are showing unit system in 'mJ' units instead of 'N' units but the values are same. Can I get help over here.?
    As well as, In the below script, what are those numbers 4,1,10,1 digits represents.
  • Ayush Kumar
    edited May 2024
    @Naveen Kumar Begari sounds like a bug. If the values are correct you can force set the units of field by field.unit = "N"
    Please report this on GitHub so that this bug can be reviewed and correct.
    https://github.com/ansys/pydpf-core/issues
    @Ayush Kumar Thank you...!!
  • Rohith Patchigolla
    Just to add to the solution, the below code can be used to directly extract the joint element id from the Joint object (using the name) in Mechanical Tree.
    analysis = DataModel.AnalysisList[0]
    solution = analysis.Solution
    jointObj = DataModel.GetObjectsByName("Fixed - 3blocks\Solid1 To 3blocks\Solid")[0]
    jointElemId = solution.SolverData.GetObjectData(jointObj).ElementId
    @Rohith Patchigolla Thanks for alternate solution.
